white smoke on muffler
Old Jul 22, 2005 | 07:13 PM
marc-111's Avatar
Default white smoke on muffler
i got a 95 GSR engine on my 93 hatch
problem is when i am on high RPM and when it hits vtec a thick white smoke comes out of my muffler and a black spots on my rear end
i did a compression test on the head cylinder 1. 235 2. 240 3. 240 4. 238
there is no oil leakage but still once in a while i add oil on my car,
BTW i changed all my gaskets and seals like head gaskets, cam seals and vtec gaskets,
what could be the problem?
Old Jul 22, 2005 | 07:16 PM
Deemeetree's Avatar
Electrician
It's normal for a little bit of smoke to appear when VTEC engages. It happens to about 99% of VTEC-equipped vehicles I see. Hell, it even happens to my 1997 Honda Accord EX.
Old Jul 22, 2005 | 07:20 PM
marc-111's Avatar
but mine is thick white smoke and black spots appear on my rear end
Old Jul 22, 2005 | 08:35 PM
papito_85's Avatar
bump, i have the same problem.
Old Jul 23, 2005 | 04:36 AM
marc-111's Avatar
Default Re: (papito_85)
help
Old Jul 23, 2005 | 04:45 AM
92ehatch's Avatar
Default Re: (marc-111)
my friends teg did that , was a piston ring
Old Jul 23, 2005 | 05:13 AM
marc-111's Avatar
Default Re: (93egsedan)
how much did he spend to change it?
Old Jul 23, 2005 | 05:16 AM
komat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marc-111 &raquo;</TD></TR><TR><TD CLASS="quote">how much did he spend to change it?</TD></TR></TABLE>
those cost alot to change
best thing to do is get a new set of rods/piston while they are out alrdy
Old Jul 23, 2005 | 05:20 AM
SixguN's Avatar
Default Re: (komat)
Was it just rebuilt? How long ago did you put gaskets on? Or did someone else do it?
Old Jul 23, 2005 | 05:23 AM
92ehatch's Avatar
i forget how much, it was a few hundred bucks
Old Jul 23, 2005 | 05:45 AM
marc-111's Avatar
that was 3 months ago since i bought the engine they changed the head gasket, valve seals and vtec gasket a friend of mine saw it when it was done,
i guess i must start working my *** double time to save a lot of money for this, might as well rebuild the engine while doing this
Old Jul 23, 2005 | 07:00 AM
illustrator's Avatar
man.. it might be ur piston rings..
Old Jul 23, 2005 | 02:51 PM
marc-111's Avatar
Default Re: (illustrator)
^^^^ how do you check it if your piton rings are worn out?
Old Jul 23, 2005 | 03:03 PM
GDR888's Avatar
Bring it to any machine shop there. If you dont know some let me know. I miss blowing my engine 3x a month and get it runnin in a couple of days. i heart QC
Old Jul 23, 2005 | 03:13 PM
marc-111's Avatar
Default Re: (GDR888)
so how do i check it by myself?
Old Jul 24, 2005 | 06:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marc-111 &raquo;</TD></TR><TR><TD CLASS="quote">^^^^ how do you check it if your piton rings are worn out?</TD></TR></TABLE>
check the blow by.. to find out if your piston rings are worn out.. and for pistons.. if you have low compression...
Old Jul 24, 2005 | 07:44 PM
marc-111's Avatar
2. 240
3. 240
4. 238
93daintegra
Jul 21, 2008 04:40 AM
newtype_civic
26
Jun 6, 2007 10:43 AM
siR cr-x
Dec 12, 2005 12:54 PM
marc-111
Jul 24, 2005 07:43 PM
NA JDM GSR
Feb 25, 2005 04:22 AM
