white smoke on muffler
i got a 95 GSR engine on my 93 hatch
problem is when i am on high RPM and when it hits vtec a thick white smoke comes out of my muffler and a black spots on my rear end
i did a compression test on the head cylinder 1. 235 2. 240 3. 240 4. 238
there is no oil leakage but still once in a while i add oil on my car,
BTW i changed all my gaskets and seals like head gaskets, cam seals and vtec gaskets,
what could be the problem?
Electrician
It's normal for a little bit of smoke to appear when VTEC engages. It happens to about 99% of VTEC-equipped vehicles I see. Hell, it even happens to my 1997 Honda Accord EX.
Re: (marc-111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marc-111 »</TD></TR><TR><TD CLASS="quote">how much did he spend to change it?</TD></TR></TABLE>
those cost alot to change
best thing to do is get a new set of rods/piston while they are out alrdy
Re: (93egsedan)
that was 3 months ago since i bought the engine they changed the head gasket, valve seals and vtec gasket a friend of mine saw it when it was done,
i guess i must start working my *** double time to save a lot of money for this, might as well rebuild the engine while doing this
Re: (marc-111)
Bring it to any machine shop there. If you dont know some let me know. I miss blowing my engine 3x a month and get it runnin in a couple of days. i heart QC
Re: (marc-111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marc-111 »</TD></TR><TR><TD CLASS="quote">^^^^ how do you check it if your piton rings are worn out?</TD></TR></TABLE>
check the blow by.. to find out if your piston rings are worn out.. and for pistons.. if you have low compression...
newtype_civic
26
06-06-2007 10:43 AM
