Ac fan and engine fan
Old Jul 22, 2005 | 06:27 PM
iLUVmyACCORD's Avatar
Default Ac fan and engine fan
when i have my ac on just idling and its like 85+ outside.. the engine temp jumps up and i quickly turn it off... the ac fan works but im not sure if the other fan is working.. when does the other fan turn on???
Old Jul 22, 2005 | 11:20 PM
deserthonda's Avatar
Default Re: Ac fan and engine fan (Negronese)
both fans should come on with a/c on .............put a/c on get a big screwdriver and hit the back side of the fan that does not work if it comes on you got a bad motor if not could be fuse, wiring , relay
Old Jul 23, 2005 | 03:03 AM
Default Re: Ac fan and engine fan (deserthonda)
i was told the other fan turns on when it feels like its heating up...
so if i start my car up right now (cold start) and i turn on ac, both fans should start working???
Old Jul 23, 2005 | 07:05 PM
if you put a/c on car hot or cold both fans should come on ...........
Old Jul 24, 2005 | 07:41 AM
codemaster63's Avatar
Default Re: (deserthonda)
I have the same problem on my 98 accord. Only one of my fans will turn on when i switch on the ac, haven't tried to hit the other fan w/ a screwdriver yet. Hopefully that will get it to start or else i probly have a busted fan motor.
Old Jul 24, 2005 | 02:28 PM
Ok im pretty sure the one fan that wont turn on is messed up. I would hit the fan that didn't move w/ a screwdriver and it will spin although very slowly compared to the other fan, and it wont spin up when I turn the ac on again. Anybody know how much one radiator fan would cost?
Old Jul 24, 2005 | 08:48 PM
Default Re: Ac fan and engine fan (codemaster63)
dealer fan motor is around $ 230 if you get a non factory ( autozone, checker,) could be around 70-80 dollars
MJMAccord
Sep 30, 2010 11:31 AM
Efbucket
Sep 3, 2007 11:55 AM
zirac50
Apr 15, 2007 06:24 PM
jazz215
17
Jul 27, 2003 05:17 PM
