Proportioning valve question???
Old Jul 22, 2005 | 05:26 PM
speedjunky77's Avatar
Default Proportioning valve question???
Do the proportioning valves (PV) on a 98’ HB and a 99 Si look the same? I’m doing the rear disk brake conversion and about to swap in the Si PV and they look the same in appearance.
Old Jul 22, 2005 | 05:46 PM
Default Re: Proportioning valve question??? (speedjunky77)
I've just read in another post that 96-00 HB and the Si (40/40) have the same prop. valve. If this is true, then why are my brakes still mushy? Booster?
Old Jul 22, 2005 | 05:49 PM
JimmyAtlantis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedjunky77 &raquo;</TD></TR><TR><TD CLASS="quote">I've just read in another post that 96-00 HB and the Si (40/40) have the same prop. valve. If this is true, then why are my brakes still mushy? Booster? </TD></TR></TABLE>
You did bleed them, right?
Old Jul 22, 2005 | 06:19 PM
yeah.
Old Jul 22, 2005 | 07:51 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedjunky77 &raquo;</TD></TR><TR><TD CLASS="quote">Do the proportioning valves (PV) on a 98’ HB and a 99 Si look the same? I’m doing the rear disk brake conversion and about to swap in the Si PV and they look the same in appearance. </TD></TR></TABLE>
Yes they are the same, weird huh? If u check the part number for the PV of the SI and hatch, u will see that the part numbers are actually the same!
go here to see http://www.slhondaparts.com
Old Jul 25, 2005 | 11:27 AM
Ok, so the Prop. Valve for 98' EK and 99 Si are both (40/40). Now I've read some posts that I need up grade my brake booster (BB) and master cylinder (MC) to the 99 Si, and other posts saying I can stick with the 98' EK BB & MC setup. Can anyone out there who has done this swap with their EK confirm this?
Thanks.
svtford4x4
Jun 14, 2012 06:47 PM
94eghatchcx
Sep 11, 2007 10:33 AM
jetpilot
12
Jun 5, 2007 03:12 PM
Viorent Grip! EG
Oct 13, 2006 09:56 AM
sicegcivic
12
Apr 2, 2004 04:03 PM
