What can I do?
Old Jul 22, 2005 | 02:03 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default What can I do?
Alright I got a d16z6 in a stock dx hatch.
Intake, header, full 2.25 inch exhaust, with es muffler
what else can I do to bump more power, I am not modding it anymore
It is dropped on Hr sports with AGX
15 inch tires
I am buying slicks, but what else can I do?
thanks
I want to run at least a high 15 if that is possible
What slicks and what size should I get on STOCK axles
thanks
Old Jul 22, 2005 | 02:38 PM
jmcmil6's Avatar
Default Re: What can I do? (MugenHonda)
w/ that motor.. small.. like maybe 22's.. not sure if u have enough power tho.. u might hurt more than help...not enough power to spin them things and u will bog, really really bad.. ever thought about nitrous?..
Old Jul 22, 2005 | 04:11 PM
MugenHonda's Avatar
Default Re: What can I do? (jmcmil6)
lol, i spent so much time putting the motor in and getting rid of all the codes, i'd be pretty pissed if i blew it up on nitrous.
regardless, I'll buy azenis, but I hope to net a 15 something
Old Jul 22, 2005 | 04:31 PM
JL's Avatar
JL
what year hatch is it?
Old Jul 22, 2005 | 05:20 PM
MugenHonda's Avatar
Default Re: What can I do? (JL)
EG 93
Old Jul 22, 2005 | 11:25 PM
EJtypeR's Avatar
nitrous wont blow your motor...unless its tired, or your **** isnt set up right. i dont get why everyone thinks nitrous blows motors.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda &raquo;</TD></TR><TR><TD CLASS="quote">lol, i spent so much time putting the motor in and getting rid of all the codes, i'd be pretty pissed if i blew it up on nitrous.
Old Jul 23, 2005 | 05:20 AM
MugenHonda's Avatar
Default Re: What can I do? (EJtypeR)
i didn't say it was going to blow, but I obviously am not going to pay up to 1k in tuning it for nitrous because its not worth it.
If I was going to 1k for tuning, it would haveto be for a turbo, which is why I rather not just throw on a nitrous kit and start shooting some nos
Old Jul 23, 2005 | 05:53 AM
hondaguyef's Avatar
In my honest opinion I think you can even get into the 14's w/ that setup. Use the Mickey Thompson 20x8x14 slicks (you can run them on 14" steelies). As for the nitrous, Big dollars don't have to be spent and the motor doesn't have to suffer. You can pick up a used dry kit on here for pretty cheap. It's an easy install and you can just retard the timing a couple degrees when using 50 shot and below. Good luck and do some research, there's alot of good info on budget setups on here.
Phil
Old Jul 23, 2005 | 06:21 AM
The $hop inc.'s Avatar
make sure you have a good clutch in it
Old Jul 23, 2005 | 10:14 AM
MugenHonda's Avatar
Default Re: What can I do? (TeamSSR)
exedy stage 2 good for up to 200hp i think?
Yeah i'll look into some slicks
thanks
Old Jul 23, 2005 | 08:11 PM
EJtypeR's Avatar
Default Re: What can I do? (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">In my honest opinion I think you can even get into the 14's w/ that setup. Use the Mickey Thompson 20x8x14 slicks (you can run them on 14" steelies). As for the nitrous, Big dollars don't have to be spent and the motor doesn't have to suffer. You can pick up a used dry kit on here for pretty cheap. It's an easy install and you can just retard the timing a couple degrees when using 50 shot and below. Good luck and do some research, there's alot of good info on budget setups on here.
Phil</TD></TR></TABLE>
couldnt have said it better myself.
2k1 GSR
Nov 19, 2013 06:10 PM
e jay one
Jul 12, 2005 05:14 PM
cisurfer1
Dec 24, 2004 03:11 PM
serious
Oct 3, 2002 06:36 PM
el_Presidente
Apr 26, 2002 01:50 PM
