b16a TB vs b18b TB
Old Jul 21, 2005 | 11:11 PM
RHDintegXsi's Avatar
Default b16a TB vs b18b TB
my setup
JDM b16a
USDM b18b TB
am i okay running the LS map sensor? i know it will run and it might even run just fine. what i need to know is..
will running a ls map sensor on a b16 affect smog any? its very important because ill be going to the ref asap
Old Jul 21, 2005 | 11:32 PM
ecovillain's Avatar
Default Re: b16a TB vs b18b TB (SINFULintegXsi)
honda obd1 maps are the same..look at the number on them. its not the sensor that is different between motors, just the way that the ecu fro each respective motor responds the the signals it receives. how will the smog ref know that you have an LS TB? they look fairly similar.
unless your car is obd0 or something, and you are using the obd1 map sensor.
Old Jul 21, 2005 | 11:39 PM
Default Re: b16a TB vs b18b TB (ecovillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ecovillain &raquo;</TD></TR><TR><TD CLASS="quote">honda obd1 maps are the same..look at the number on them. its not the sensor that is different between motors, just the way that the ecu fro each respective motor responds the the signals it receives. how will the smog ref know that you have an LS TB? they look fairly similar.
unless your car is obd0 or something, and you are using the obd1 map sensor.</TD></TR></TABLE>
cool..i almost bought a map sensor from an OBD1 b16a2
thanks bro
95b16rr
Oct 10, 2008 05:11 PM
Hatchman98
Nov 28, 2006 04:43 PM
CBURKE
Jan 7, 2006 12:08 PM
EF_LEGOMAN
10
Dec 14, 2005 12:08 PM
Rywire
Feb 16, 2003 09:03 PM
