distributor turned all the way and cant get past 14 deg, help how can i trick it to set timing
Old Jul 21, 2005 | 05:28 PM
srv3fender's Avatar
Default distributor turned all the way and cant get past 14 deg, help how can i trick it to set timing
Ive got the plug jumped and im turning the dizzy the right direction to advance but i cant turn it anymore , i need to get it to atleast 16 degrees but im shooting for 18 degrees
can anyone help me trick the computer
Old Jul 21, 2005 | 05:31 PM
NastyHabitzCRX's Avatar
did you recently do the timing belt? sounds like your one tooth off
Old Jul 21, 2005 | 05:33 PM
srv3fender's Avatar
Default Re: (NastyHabitzCRX)
no timing belt hasnt been changed
and at one point it was reading 16 degrees
Old Jul 21, 2005 | 06:58 PM
Kwicko's Avatar
Default Re: (srv3fender)
I agree... Sounds like you're off by a tooth. Maybe the t-belt *jumped* a tooth?
Mike
Old Jul 21, 2005 | 07:02 PM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
Default Re: (Kwicko)
are u using an oem dizzy or aftermarket? aftermarket tend not to advance as far. u need to to get an air grinder and cut off the tabs so u can turn it more.
Old Jul 23, 2005 | 03:54 PM
srv3fender's Avatar
Default Re: (floss)
what tabs?
even if i drilled the slots , those few millimeters probably would be enough space to get it up to 18 degrees
its not really an aftermarket dizzy, its an 88-91 si , granted its not the one the went with the engine (d16y8) but it still works and its got the matching computer (pm6)
im pretty sure its not off by a tooth because its been in-time before not just on one occasion, and a timing belt cant slip like a serpantine drive belt will
if i could just get it to reset itself to 16 degrees tdc without adjusting the distributor , i would be fine
Old Jul 23, 2005 | 04:47 PM
srv3fender's Avatar
anybody got any ideas
can u still use the vacuum advance trick
Old Jul 23, 2005 | 08:57 PM
Crx Jimmy's Avatar
Default Re: distributor turned all the way and cant get past 14 deg, help how can i trick it to set timing (
if it was off a tooth it wold probably be only 10-12 degrees max i had that problem, i think the most i could get out of it was 12 degrees with slotting the dizzy more, thats what i would do if you need a little more adjustment, take a dremel and slot the holesbigger, also you can slot the hole in the rotor and get a degree or 2 that way
Old Jul 23, 2005 | 09:46 PM
sanimalp's Avatar
$cat /dev/urandom
well i agree that you might be off a tooth, but the only way to change timing that much is to get an adjustable cam pulley. that will let you set the pulley to a certain degree forward or back, and then you can set your distributor to fine tune it where you want.. but.. why so much advance?? advance doesnt just = free power..
Old Jul 24, 2005 | 07:58 AM
civic_dork's Avatar
not 100% sure, heck more like 20%... so just a guess...
doesn't 91si have the radio/interrupt bareel gizmo mounted to the fire wall, while older ones had it on the dizzy? So therefore you now don't have one of those attached?
Just thinking maybe the lack of that 'thing' makes the signal get there a few milliseconds early, therefore throwing ignition timing off by a few degrees?
(i'm wondering cuz i now have the opposite problem of you, i have 2 of them now (opposite change out as you), and my timing is right, but the ignition timing just barely can be set to factory spec)
Old Jul 24, 2005 | 11:25 AM
suspendedHatch's Avatar
No, you can't trick the ECU. Just fix the problem.
I would TDC the motor and make sure the crank pulley is on right. I've seen them forced on smashing the keyway to ****. I've seen them on wrong with no key. Make sure you're using the right marks on the pulley to set timing.
I'm a bit new to the OBD0 motors, but I had a similar problem when I put a SOHC ZC vtec into my 93 DX. I had to reuse the DX distributer. It fit, but it didn't have enough timing adjustment so I had to get a EX distributer. So maybe it's the wrong distributer?
zedjr
Sep 4, 2017 07:05 PM
Hondatastic
Aug 19, 2016 02:58 PM
killgore
May 12, 2013 03:10 PM
92egSnatch
Apr 20, 2008 07:06 PM
InTeGrA B18b1
Apr 20, 2006 09:30 PM
