How do you remove the rear seats?
if you lift up the bottom part of the seats youll see each lower cushion has 2 clips on either side. you gota pull the clip and lift the seat up, once you get the bottom part off the top part is attatched by 3 small bolts
I tried removing the seats the other day by pulling on the clips. They dont come out at all when i pull on them. Do i just need to pull hard? I dont want to break theym.
When I pulled on the tab thingies I needed to get a good grip with some pliers. They will kind of pop... you'll know when they've been pulled. They the seat justs lifts up.
Spoon92
Aug 29, 2003 09:51 AM
