QUICK! Are 96-00 civic EX and DX coupe exhausts the same?
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
My buddy has a 96 civic DX (non-VTEC) coupe midpipe; I have a 97 civic EX.
Will his mid-pipe bolt up to my stock cat? I have a stock EX muffler already..
Also, do 99-00 Si mid-pipes bolt up to civic EX's?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deemeetree »</TD></TR><TR><TD CLASS="quote">If it's your buddy, install it. If it works, give yourself a high-five. If it doesn't, slap yourself and remove it.
Yes, it should work if they are both Coupes.</TD></TR></TABLE>
Cool. The cat locations aren't different for an EX and DX, with respect to the stock cat?
99-00 Si too?
99-00 Si too?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reddohcvtec »</TD></TR><TR><TD CLASS="quote">Yea Si exhausts are the same as 96-00 Ex's</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe »</TD></TR><TR><TD CLASS="quote">My buddy has a 96 civic DX (non-VTEC) coupe midpipe; I have a 97 civic EX.
His mid pipe will bolt directly to your header and you will not be able to use your cat because the DX mid pipe is londer than the EX mid pipe.
Si mid pipes are the same as EX mid pipes except the Si may be larger in diameter.
</TD></TR></TABLE>His mid pipe will bolt directly to your header and you will not be able to use your cat because the DX mid pipe is londer than the EX mid pipe.
bmoua
Aug 11, 2009 06:48 AM
boostincoupe
Jul 1, 2005 04:21 AM
Punker1234
Apr 4, 2005 11:22 AM
