hondata on crx
Old Jul 21, 2005 | 12:40 PM
spoonzdelsol's Avatar
Default hondata on crx
okay i am converting over to obd1 and i was wondering if i can use my dsm injectors with hondata as my FMU ? and if not what should i do? its for a turbo setup
Old Jul 21, 2005 | 12:45 PM
BlueShadow's Avatar
Default Re: hondata on crx (spoonzdelsol)
you can use Hondata to control injectors from stock size all the way up to 1000cc's. Just make sure you wire in some resistors for the DSM 450's since they are peak and hold. BTW FMU is usually what people call the boost dependent FPR's. Even through it does stand for Fuel Management Unit, people commonly associate the term with boost dependent FPR's.
Old Jul 21, 2005 | 01:52 PM
i have the resistor box on my crx does that make a diffrence
Old Jul 21, 2005 | 02:16 PM
BlueShadow's Avatar
Default Re: (spoonzdelsol)
You can wire it up to those DSM 450's and you should be good to go. you might wanna check the resistors though to make sure they still work. Check out the first thread at the top of the FI forum. There are a lot of threads in the FI FAQ on how to hook up DSM 450's.
gsrhatch530
Dec 16, 2003 03:48 PM
B18PoweredCivic
Jun 1, 2003 05:32 AM
PressurizedSi
Feb 2, 2003 10:31 AM
PressurizedSi
Jan 9, 2003 10:22 PM
LEON
May 31, 2002 10:38 AM
