GAUGE CLUSTER??
CAN ANYONE HELP ME TRYING TO FIND A PROBLEM WHY MY GAUGE CLUSTER LIGHTS, JUST QUIT WORKING? IT IS NOT THE FUSE THAT WAS THE FIRST THING I CHECKED. I DONT KNOW IF IT HAS ANY THING TO DO WITH MY DASH SWAP I DID, BECAUSE THE LIGHTS WORKED FINE UNTIL I HOOKED UP MY HAZARD SWITCH THAT IS WHEN I NOTICED THE PROB. SO I TOOK THE SWITCH OFF AND STILL NO LIGHTS. SO CAN ANYONE HELP?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR95DXHATCH92 »</TD></TR><TR><TD CLASS="quote">I DONT KNOW IF IT HAS ANY THING TO DO WITH MY DASH SWAP I DID, </TD></TR></TABLE>
If everything worked, then you did a dash swap, and now something's wrong, chances are you messed something up with the reinstall. (forgot to plug something in perhaps?)\
btw: turn you caps lock off.
well i know in alot of 92-95 civic, or at least it seems like, the dimmer switch goes bad... which just needs a quick replacement..
but i just noticed you did say you swapped your dash, so i would guess your wired something up wrong, so check that first before you go buyin a new dimmer or anything..
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EgGriff »</TD></TR><TR><TD CLASS="quote">well i know in alot of 92-95 civic, or at least it seems like, the dimmer switch goes bad... which just needs a quick replacement..
but i just noticed you did say you swapped your dash, so i would guess your wired something up wrong, so check that first before you go buyin a new dimmer or anything..</TD></TR></TABLE>
I agree, double check the wiring, you soldered and heat shrinked the wiring right? Usually butt connectors tend to **** things up at times so don't use those..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR95DXHATCH92 »</TD></TR><TR><TD CLASS="quote">it is the dimmer switch i took the one out of my tegg and put it in and it worked thanks for the help</TD></TR></TABLE>
Awesome yes, if the dimmer switch doesn't work your dash won't light up. Glad we could help.
Antonio_P.R
Oct 21, 2008 09:52 AM
Jay.D.Em!
Apr 17, 2006 07:17 PM
veganej
Aug 26, 2004 06:52 PM
