Would these cams be over kill????
Old Jul 21, 2005 | 05:52 AM
sprayin95hatch's Avatar
Default Would these cams be over kill????
ok i have a stock internal b16 with every bolt on and its time to start getting into the internals. i was wondering if skunk 2 stage 2 cams would be overkill for my stock compression as of right now. in the future i plan on raising it but im buying the cams now so i want somthing that will help alot now, but also still work good later.
also anyone got any good recomendations on valve springs that are good to 9k-10k
Old Jul 21, 2005 | 06:49 AM
91civicDXdude's Avatar
I'm running comp/zex 57200 cams on my stock block b16a3, skunk2 valvetrain and the engine has seen 9500 many times.
Old Jul 21, 2005 | 11:47 AM
ya, sry i dont thin k you understood. my question was would these cams do well in my car right now with stock compression
Old Jul 21, 2005 | 11:58 AM
vinasity's Avatar
Default Re: (sprayin95hatch)
omni power the new rocket and skunk2 springs are also good. I dont think you need to rev to 10k for power. As for compression there are many ppl runnig those cams on stock compression
Old Jul 21, 2005 | 12:42 PM
philafelman's Avatar
Default Re: (vinasity)
i ran skunk2 stage 2's with gsr head/stock jdm b16 block-completely sucked ***...i think it was slower than a stock b16.
Old Jul 21, 2005 | 01:25 PM
what made it suck ***. maybe tuning skills?
Old Jul 21, 2005 | 02:29 PM
o ya if i got stage 1s now, will those do good when i raise the compression to about 11.5:1
Old Jul 21, 2005 | 02:47 PM
i dont think i had enough compression/displacement to make them show any gains. ive got them on my 11.5:1 gsr motor now, and they rock the house.
Old Jul 21, 2005 | 07:57 PM
ok kool. my compression will be 11:1 prob when i get them....i just want to make shure im getting the best power. so even with stock compression i would be ok 4 a while without loosing power?
Old Jul 21, 2005 | 08:40 PM
UncleD's Avatar
You MIGHT gain power with them from 7k on, but personally I would opt for a type r camshaft or maybe a S2S1....never underestimate the power of a type r cam....
Old Jul 24, 2005 | 02:34 PM
after what everyone is saying i think im might just go with the s2s1...because from what i understand they will be good now, and they will still be good when i raise the compression to 11.5 or 12...
Old Jul 24, 2005 | 07:39 PM
illustrator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sprayin95hatch &raquo;</TD></TR><TR><TD CLASS="quote">after what everyone is saying i think im might just go with the s2s1...because from what i understand they will be good now, and they will still be good when i raise the compression to 11.5 or 12...</TD></TR></TABLE>
those S2s1 cams are like ITR/CTR cams.. might as well get OEM honda parts for quality...
check this out.. this would help you out... http://faq.ef-honda.com/index....ng=en its a B-series cam guide from EF-Honda.com
Old Jul 24, 2005 | 10:05 PM
spockeg's Avatar
Default Re: (illustrator)
i would recommend stage1, stage2 like 12:1+ cr motors
serr38
Oct 31, 2007 12:45 PM
martyball619
Oct 24, 2006 09:07 AM
MugenB18cTeC
Jun 11, 2004 09:02 AM
Halive
22
Jun 28, 2002 02:33 PM
