Spoon Stroker Kit
Old Jul 21, 2005 | 02:45 AM
davehewitson's Avatar
Default Spoon Stroker Kit
Will I be able to run a spoon B16b stroker kit on a B16a? Will the crankshaft and conrods fit into my engine?
thanks
Dave
Old Jul 21, 2005 | 03:23 AM
Default Re: Spoon Stroker Kit (davehewitson)
anyone know?
Old Jul 21, 2005 | 05:26 AM
touringe17a's Avatar
hi there dave,
it's depent what kind of stroker kit u wanna use. as far as i know, b16a block can be fitted with 1.9 liter destroker kit.
correct my if im wrong guys ?
thanks.
Old Jul 21, 2005 | 05:28 AM
CYBERCRXT's Avatar
Nope, The B16A has a lower deck height than the B16B...Actually the B16B and B18C1/5 blocks are the same..Just the B16B crank is destroked. The spoon stroker kit is for a B16B. So, if you run this kit in your B16A block, your pistons will ram the bottom of the cylinder head. I studyed this kit when I was building my all motor B16A..where I realized it will not work. Mike
Old Jul 21, 2005 | 06:16 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: Spoon Stroker Kit (CYBERCRXT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CYBERCRXT &raquo;</TD></TR><TR><TD CLASS="quote">Nope, The B16A has a lower deck height than the B16B...Actually the B16B and B18C1/5 blocks are the same..Just the B16B crank is destroked. The spoon stroker kit is for a B16B. So, if you run this kit in your B16A block, your pistons will ram the bottom of the cylinder head. I studyed this kit when I was building my all motor B16A..where I realized it will not work. Mike</TD></TR></TABLE>
order a jun kit cheaper will fit and cosworth made pistons mmmmmmm
crower and toda also make awesome kits.
Old Jul 21, 2005 | 09:40 AM
TodaCivic's Avatar
Default Re: Spoon Stroker Kit (Ace$nyper)
Yea the pistons will poke out of the block too far.
Go for the techedge kit that uses a ls crank and custom rods.
But you could always sleeve the b16 and do 84mm and have a 1.8 liter.
I think that would be best and you'd keepthe awesome rod/stroke ratio... local guy has it here and hits close to 200whp.
DA dude
Jan 10, 2005 07:07 PM
mikecivichb
15
Oct 5, 2004 08:23 PM
kingfrost
Mar 4, 2003 06:23 PM
ATS*Mark
21
Feb 9, 2003 08:12 AM
p-boy
Aug 13, 2002 09:01 AM
