*HELP* Injector Trouble
Old Jul 20, 2005 | 06:49 PM
bootlegcivic's Avatar
Default *HELP* Injector Trouble
My car won't start because the inectors aren't pulsing. I have fuel in the rail and spark. I've tried 3 ECU's and 2 wiring harnesses. I think they work off of the cam position sensor which is in the distributor right? The distributor is brand new.
What could be the problem???
Old Jul 20, 2005 | 06:51 PM
Crank's Avatar
Default Re: *HELP* Injector Trouble (bootlegcivic)
are you pulling any cel codes?
Old Jul 20, 2005 | 06:59 PM
Corporation's Avatar
Economic Upturn, WUT
From: Alittle Placed Called None of Your Damn Business.
Default Re: *HELP* Injector Trouble (Crank)
Did you change your injectors or did the wires come undone?
::EDIT:: Check distributer wiring
PS. Bro, give us more detail, did you swap the motor? what kind of car?
Old Jul 22, 2005 | 11:39 PM
Default Re: *HELP* Injector Trouble (ahrpr)
No there isn't any codes cuz it won't turn on and the injectors are stock d16z6 in a b16,
*JDM B16a with a D16z6 harness in a 93 civic hatch si*
Thanks
Old Jul 23, 2005 | 06:55 AM
Ok, the car should have power, so turn the key like your listening to the radio. A CEL will come on then.
I'm not sure about EGs but in the EFs there is this little blue plug on the passenger side that is up by the dash, it has 2 little ports. You take a small wire and you plug it into one side and plug it into the other.
When you do this. The CEL will blink on your cluster, one long blink is 10 and short fast blinks are 1. So 2 long blinks and 3 short is code #23. Try this and get back to us.
Old Jul 24, 2005 | 10:30 PM
Never mind guys. It turned out to be 2 ground wires that feed to the ecu. They were missing on the harness. Thanks for the help though.
Old Nov 6, 2009 | 07:26 PM
frizzle's Avatar
does anyone know why my obd1 b16a would run fine and rev all the way out but still have a code 16 (injectors) from time to time its hard to keep running without a tap from the pedal while cranking. otherwise it just dies instantly. warm days its fine but cold i have the most trouble and it takes alot of cranking to get it in cycle.
Old Nov 6, 2009 | 07:28 PM
frizzle's Avatar
its swapped into an ef si by the way and the codes comes one when the car starts. relay? or what because i hear the pump. is it a ground prblem?
93CX
13
Mar 16, 2014 04:21 AM
cj90si
Nov 15, 2012 01:10 PM
dre33333
Nov 11, 2012 09:36 AM
93WhiteHatch
Jul 29, 2010 11:16 AM
Krayzielix
Feb 14, 2003 09:42 PM
