TDC Positioning
Old Jul 20, 2005 | 06:31 PM
LSEGHATCH's Avatar
Default TDC Positioning
Ok, I'll start off by saying that I should've bought a Helms manula instead of the Haynes and can you locate TDC w/o having to go under your car? If you can do it that way, what is the easiest way. Its dark and I have shitting lighting (shadows) so I can't really see where much is and might have to wait until daytime.
Old Jul 20, 2005 | 06:56 PM
LSEGHATCH's Avatar
Default Re: TDC Positioning (LSEGHATCH)
Usually I don't bump this soon and it probably is against forum policy, but I really need this so I can finish this up before tomorrow.....
Sorry
Old Jul 20, 2005 | 06:57 PM
Corporation's Avatar
Economic Upturn, WUT
From: Alittle Placed Called None of Your Damn Business.
On your crank pulley there are these markings one is || and other is ||| you need to line the || up with teh arrow under the cam gear and the other goes to another position arrow. Search for "Poison timing belt" he gives a really good how to. Have a good time.
Old Jul 20, 2005 | 07:53 PM
LSEGHATCH's Avatar
Default Re: TDC Positioning (ahrpr)
Didn't find anything that answered my question, anyone else......Once again, I am asking if there is a way to move the timing belt w/o going underneath the car. I need to get the #1 piston to TDC before I take the head off and such.....
Old Jul 20, 2005 | 07:59 PM
e jay one's Avatar
so you need to turn the motor over till it gets to tdc? use a socket on the crank bolt. b or d motor?
Old Jul 20, 2005 | 09:34 PM
LSEGHATCH's Avatar
Default Re: TDC Positioning (e jay one)
Yeah that's what I wanna do but I can't get access underneath the car for now and it's a D-Series
Old Jul 20, 2005 | 09:40 PM
JDubbs99Civic's Avatar
the bolt to turn the crank is on the drivers side in the wheel well area, its not under the car.
Old Jul 20, 2005 | 09:43 PM
LSEGHATCH's Avatar
Default Re: TDC Positioning (JDubbs99Civic)
So do I take the wheel off and the plastic liner(which I can do). Turn the crank bolt (clockwise is it?) then when it reaches TDC do I just slide the belt off or should I go the tensioner route?
EdwinCheng
May 7, 2014 01:28 PM
jodyboy
10
Jun 29, 2012 05:47 PM
93EJ1gsr
Oct 26, 2006 01:01 PM
nfinitecc
21
Nov 28, 2004 02:22 PM
brockscivic
Jul 6, 2004 10:07 AM
