Need low PSI wastegate springs.
what size wastegate are you running? You need a small yellow.
Wastegate - 35mm
BAR // PSI // Color // OD
0.30bar // 4.35psi // Sm. Yellow // 1.875in
0.45bar // 6.53psi // Sm. Red
0.65bar // 9.43psi // Sm. Green
0.8bar // 11.60psi // Sm. Blue
Wastegate - 35mmHP
0.95bar // 13.78psi // BigYellow // 1.875in
1.10bar // 15.95psi // BigRed
1.35bar // 19.58psi // BigGreen
1.5bar // 21.75psi // BigBlue
Wastegate - 38/40mm
0.25bar // 3.63psi // Sm. Yellow // 1.875in
0.4bar // 5.80psi // Sm. Red
0.5bar // 7.25psi // Sm. Green
0.6bar // 8.70psi // Sm. Blue
0.7bar // 10.15psi // Big Yellow 2.36in
0.8bar // 11.60psi // Big Red
0.9bar // 13.05psi // Big Green
1.0bar // 14.50psi // Big Blue
1.1bar // 15.95psi // **
1.2bar // 17.40psi // **
1.3bar // 18.95psi // **
1.4bar // 20.30psi // **
1.5bar // 21.75psi // **
1.6bar // 23.20psi // **
Wastegate - 44/46mm
0.2bar // 2.90psi // Sm. Yellow // 1.875in
0.3bar // 4.35psi // Sm. Red
0.4bar // 5.80psi // Sm. Green
0.5bar // 7.25psi // Sm. Blue
0.6bar // 8.70psi // Big Yellow // 2.36in
0.7bar // 10.15psi // Big Red
0.8bar // 11.60psi // Big Green
0.9bar // 13.05psi // Big Blue
1.0bar // 14.50psi // **
*All Standard WG35mm Springs can also be used for WG35mmHP
**You can combine Big&Small Springs to get the PSI that you need for HP
Wastegate - 35mm
Wastegate - 35mmHP
Wastegate - 38/40mm
Wastegate - 44/46mm
44mm. Is that what you are offering, if so I'll PM you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spike »</TD></TR><TR><TD CLASS="quote">I think I might have a 6.5psi for a TiAL 35mm.. looking to trade for a ~15psi spring.</TD></TR></TABLE>
Too small, and I need something as close to the 3PSI as possible. Thanks though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NidStyles »</TD></TR><TR><TD CLASS="quote">44mm. Is that what you are offering, if so I'll PM you.
Too small, and I need something as close to the 3PSI as possible. Thanks though. </TD></TR></TABLE>
I was just posting that up so you can see what color you needed. I PM'd you with multiple places to purchase them from... Good luck
turbo*s2k
Northern California (Sales)
12
Oct 13, 2006 02:46 PM
Hoosier Daddy
Jul 20, 2005 04:37 AM
