Over torqued arp head studs
no dont loosen them. Just use them as they are. Just pay attention next time and torque them in like 4-5 steps. I did mine in 8 steps. best to be safe than sorry.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTErnie Motorsports »</TD></TR><TR><TD CLASS="quote">no dont loosen them. Just use them as they are. Just pay attention next time and torque them in like 4-5 steps. I did mine in 8 steps. best to be safe than sorry.
3-4 steps is plenty. If its your first time torquing them, loosen and retorque them to the same specs about 3 times so you don't have to pull the cams to retorque them in a few hundred miles.
</TD></TR></TABLE>3-4 steps is plenty. If its your first time torquing them, loosen and retorque them to the same specs about 3 times so you don't have to pull the cams to retorque them in a few hundred miles.
No it will be fine. I even took the head back off after tourqing down (forgot dowel pin in cam cap) and put it back on, tq'ed back down and everythings fine 10-15psi later!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hybridsol »</TD></TR><TR><TD CLASS="quote">3-4 steps is plenty. If its your first time torquing them, loosen and retorque them to the same specs about 3 times so you don't have to pull the cams to retorque them in a few hundred miles. </TD></TR></TABLE>
Umm you would still need to retorque them anyhow because after the block reaches operating temperature, the threads expand at a different rate than the studs, etc.
Retorquing it cold is just about as useless as washing my car three times in a row
Which engine are you running? The H series studs are torqued to 78-80ftlbs.
If you are running D series studs... then yea... you went overboard.
I believe B series are in the low 70's so a few extra lbs is not going to lead to severe bolt stretch. The ARP's are designed to be used time and time again unline stock studs.
The proper way install them is to torque the actual studs in the block, which I put at around 12-15ftlbs then a 3 stage torque sequence. 30-58-79 in the criss-cross sequence as noted in your helms manual.
Turbo E
Oct 31, 2004 01:50 PM
