I HATE THE TPS!!
Old Jul 19, 2005 | 04:12 PM
jonathan13's Avatar
Default I HATE THE TPS!!
i have a 94 del sol with the b16 motor and my idle is all messed up.. ive been to 3 shops who have no idea what they are doing... my idle is at a steady 3000 and i just put a new tps on there.. ive tried it twisted every way possible on the throttle body and nothing helps.. i have no idea what to do.. any help is GREATLY appreciated!!
Old Jul 19, 2005 | 04:18 PM
2lua's Avatar
Default Re: I HATE THE TPS!! (jonathan13)
you can twist the tps all day long and it not gona help. you need a dvm and spec out the tps.
at idle it should be at .45v to .5v
at wot it should be at 4.5v to 5v
Old Jul 19, 2005 | 04:22 PM
jonathan13's Avatar
Default Re: I HATE THE TPS!! (2lua)
ok dvm.. digital volt meter.. got that but other than that i have no idea what your talking about.. how exactly do u adjust it.. if i need a dvm ill go buy one right now lol i just want to get this fixed .. its so annoying and wasting all my gas and no one in my little hick town knows what they are doing including me!! lol plz elaborate as much as possible. THANKS!!!!
Old Jul 19, 2005 | 04:27 PM
JDM-97CX's Avatar
Have you checke your idle air control? You know, that little thing that controls your idle.
Old Jul 19, 2005 | 04:33 PM
jonathan13's Avatar
Default Re: I HATE THE TPS!! (JDM-97CX)
no.. and i know that sounds stupid but i just bought the car two weeks ago and its my first honda and im tryin to learn as much as i can but im still VERY much a newb.. but it sounds like that very well could be the problem...where is it located and how can i adjust it? thanks.
Old Jul 19, 2005 | 04:42 PM
2lua's Avatar
1st find a t-pin so you can pierce the wire.
turn the ignition key on.
measure the red/blu + and grn/wht -
it should read approx .45v to .5v at idle
it should read approx. 4.5v to 5v at wot = wide open throttle
if not at spec. slowly loosing the screws the turn the tps to spec.
this assume that you have make sure your wiring are good, and you have not mess with idle screw.
Old Jul 19, 2005 | 04:45 PM
six_speed's Avatar
the iacv(idle air control valve) is located in the back of the intake manifold. it's held on by (2) 12mm bolts and it has (2) coolant hose connected to it.
take it out and clean the metal mesh w/ break cleaner.
Old Jul 19, 2005 | 08:10 PM
jonathan13's Avatar
Default Re: (six_speed)
well i got it fixed... turns out it was the idle air control valve. when you shook the throttle body you could hear somethin rattling so we took it apart and the valve had come apart and all we had to do was screw it back together and it idles perfect now. Thanks everybody for your help.
Brockasaurus
Nov 23, 2011 12:02 AM
schools94
28
Jul 21, 2010 07:43 PM
gsrpowercrx
Dec 7, 2008 06:52 AM
DJ_SaNdOz
Mar 4, 2003 08:34 AM
cirionrc
Apr 27, 2002 10:47 AM
