Need some help w/ Tranny Housing!! Damn Thing Won't Fit Together!!!
Old Feb 17, 2002 | 07:13 PM
AmauryR's Avatar
Default Need some help w/ Tranny Housing!! Damn Thing Won't Fit Together!!!
Ok, here's my problem (for a while), tranny case won't fit back on. At first I thought that damn circlip thing was blocking the case but that wasn't it, and the dowel pins aren't touching either. I'm stumped! I'm supposed to start my swap tommorow but I can't get my tranny together, someone help plz!
PS. The only reason I opened up the case was to remove the shift rod (that connects to the shift linkage) so I can punch out the linkage-pin. I unbolted that, the bolt w/ the spring + the ball-brg and the mechanism thing that does the shifting (dunno, but it has 3 10mm bolts). I bolted everything back together (to my knowledge) and noticed it doesn't shift easily (mayb b/c there is no oil in there), but my main focus is now the actual getting the case back on, so plz. guys come thru.
Thanks.
Old Feb 17, 2002 | 09:17 PM
SpeedracerS4's Avatar
Default Re: Need some help w/ Tranny Housing!! Damn Thing Won't Fit Together!!! (SKiLLz-R)
Play with the shift rod , the reason it wont close is because the shift fork is not align right. You need to play with the shift rod, when I say play I mean shift it into gears. Once it goes down, dont forget the snap ring. Hope this helps
Old Feb 18, 2002 | 03:32 AM
AmauryR's Avatar
Default Re: Need some help w/ Tranny Housing!! Damn Thing Won't Fit Together!!! (SpeedracerS4)
Thanx, I'm gonna try that - I heard 3rd gear, 4th gear, etc... I can't seem to get it to go into 1st or 5th, etc... the shift rod won't "tilt" to let me select the other gears - could that be b/c of lack of oil? or could've it been b/c I tightened something too much (bolts were @ 5-6lb/ft).
[Modified by SKiLLz-R, 1:37 PM 2/18/2002]
Old Feb 18, 2002 | 05:06 AM
Mista Bone's Avatar
D Tranny Guru
mainshaft oil slinger not aligned..........
Old Feb 18, 2002 | 07:41 AM
AmauryR's Avatar
Default Re: Need some help w/ Tranny Housing!! Damn Thing Won't Fit Together!!! (Mista Bone)
coo, so how can I align this thing? does it happen by shifting gears manually, or is there a trick to this procedure? thnx.
Old Feb 18, 2002 | 09:42 AM
boomslang's Avatar
Sounds like one of the shift forks isn't aligned. It's happened to me before.
Old Feb 18, 2002 | 10:00 AM
Dokta's Avatar
Default Re: Need some help w/ Tranny Housing!! Damn Thing Won't Fit Together!!! (Inlinefour)
Same thing happened to me after I rebuilt my tranny. It wouldn't shift into 1/2 or 5/r. I wasn't sure what the problem was, but I didn't want to put it all together to test it and realize that I would have to take it all apart again. I traced the problem down to the interlock guide bolt. It is an allen head bolt that points from the clutch bell housing towards the tranny. I filed down about 1/8" off the end of it, and I was able to shift just fine. That was 25,000 miles ago and no problems yet.
Oh, and the tranny case is a bitch to get back on. Speedracer is right, just keep playing with it until it slips on. Don't force it.
Old Feb 18, 2002 | 05:52 PM
AmauryR's Avatar
Default Re: Need some help w/ Tranny Housing!! Damn Thing Won't Fit Together!!! (Dokta)
Oh crap, I think I'm lost - I'm not sure where this "interlock guide bolt" is at, is it around the where the shifter-rod goes to that mechanism looking thing? I dunno, think I'll just bring it to this shop in hartford that deals w/ hybrids. Crap this sux, another day lost
Old Feb 19, 2002 | 09:17 AM
Dokta's Avatar
It's real easy to find. Hey are you in hartford, CT? I live in hartford, so if you need I could probably come over and help you out. E-mail me at teraflop2001@hotmail.com and give me your phone #. I have some time tomorrow between 11am and 4pm. Every shop that I know in hartford are frickin idiots. I would never bring my car to any of them.
Old Feb 19, 2002 | 07:04 PM
AmauryR's Avatar
Yeah, unfortunately I saw this post after I dropped my tranny off @ M+T in the north end. I kinda trust them, but I also like learning how to do this stuff by myself instead of paying sum1 my hard earned $$$ to do something I can do. But anyways, I e-mailed you, so hit me back up.
Dr.Fixit
Oct 22, 2013 12:42 AM
mmmbrapND
Transmission & Drivetrain
Apr 7, 2009 06:18 PM
user7889
Oct 3, 2008 03:50 PM
AViciousTHRUST
Dec 6, 2006 12:11 AM
Aespooncivic
May 7, 2005 09:23 PM
