b16a trouble
Old Jul 19, 2005 | 11:37 AM
nickcrx's Avatar
Default b16a trouble
i have a problem please help. just swaped a b16a in my 89 rex. every thing went perfect, i start it up and i have 4 codes on my ecu 6,9,10,23. i do my research and find out they are, INTAKE AIR TEMP SERSOR, COOLANT TEMP SENSOR, KNOCK SENSOR, CYLINDER POSITION SENSOR. so i changed my coolant temp sensor and and bought a brand new distrubuter (something i needed to do, i was told by two different shops) and wired my knock sensor to pin out b19, and got a new intake air temp sensor, but nothing the codes are still on the ecu. i was told that my wiring had to be bad. if anybody has any suggestions please help thanks
Old Jul 19, 2005 | 11:41 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: b16a trouble (nickcrx)
Usually multiple codes are a sign of a bad ground..
Make sure the wiring harness is grounded
at the thermostat housing..
Also,did you clear the codes? If not,
pull the hazard fuse under the hood
for at least ten seconds to do this..
Old Jul 19, 2005 | 11:54 AM
nickcrx's Avatar
Default Re: b16a trouble (88DXCRX)
the grounds are all there i went over that, and i was told that if you disconect the battery for 10 minutes it should clear the ecu. i did it and still there is that all there could be
Old Jul 19, 2005 | 01:01 PM
Suck my DX's Avatar
faulty connection
Old Jul 19, 2005 | 01:23 PM
nickcrx's Avatar
Default Re: b16a trouble (Suck my DX)
what do you mean faulty connection. i just went out there and wanted to see how it ran and my v tech wont kick on any more, the car sat for a week or so and before vtech worked fine. my cars rpms are a 630 i s that normal im allways used to seeing them at like 800 or some where around there. if some one can give me suggestions that would be great im i really miss my car. thanks
Old Jul 19, 2005 | 01:27 PM
Suck my DX's Avatar
vtec wont work with that many codes...i g2g right now but ill answer ur question when i get back
Old Jul 19, 2005 | 01:37 PM
nickcrx's Avatar
they work just fine before cause i have the apex i vafc conected
Old Jul 19, 2005 | 03:18 PM
Suck my DX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickcrx &raquo;</TD></TR><TR><TD CLASS="quote">they work just fine before cause i have the apex i vafc conected </TD></TR></TABLE>
DUNANA....IM SORRY PLEASE CHECK UR GRAMMAR AND TRY AGAIN..
i dont get it...so do u have vafc currently connected or not?
Old Jul 19, 2005 | 09:28 PM
nickcrx's Avatar
yes i do have the vafc connected at this time. vtech work like it should before i parked it which was a week ago. now that i wanted to get a idea of how it ran the vtech wont kick on anymore.
Old Jul 20, 2005 | 06:12 AM
Suck my DX's Avatar
have a known professional double check ur wiring of the vafc...like i said ur vtec is not gonna work with that many CELs flashing....check ur wiring and report back
Old Jul 20, 2005 | 07:31 AM
Keith P's Avatar
Get a chiltons, goto the ECU, check that all the wires that should be grounded are actually grounded.. I always use a snap-on computer safe test light.
Old Jul 20, 2005 | 10:35 AM
crx-treme's Avatar
Default Re: b16a trouble (Keith P)
i believe 3 if not all of those have the same plug! i had multiple codes when i first started my b16, switched those plugs around and what do u know no more codes! the coolant temp sensor and vtec wires have the same type plug, try switching those. intake air temp and knock sensor have the same plug, switch em. idk about the cylinder po sensor, nor do i know anything about the vafc, but try this and get back to us
Old Jul 20, 2005 | 12:42 PM
nickcrx's Avatar
Default Re: b16a trouble (crx-treme)
k i notice that my vafc is reading my rpms at 600 at idle and my gauge cluster says 800 but when i drive my car the vafc is a 1000 or more rpms off. my vtech is set to kick in at 4200 but when i drive the rpms wont read any higher than 3800 but my cluster says 6000 + what could that be my vafc, my distributer my ecu. thanks for any info you guys can provide.
LuckyJDM
Dec 8, 2012 10:28 PM
Bendito
26
Apr 23, 2012 01:49 PM
ahloung
Mar 15, 2006 11:59 AM
crx-treme
15
May 8, 2005 11:21 PM
Red AEM Civic
10
Dec 11, 2003 12:18 AM
