B16 build question
If i put an LS crank and rods in a B16 block will it stroke it out to 1.8 liters?
Or should i stick with the LS vtec build
Im not scared of either but which one would be a better set up, LMK
thanks
thanks
i would stick with a ls/vtec as u can do that ls crank to a b16a block
but u will only be able to use the tech43 pistons set up and which kinda looks and heard works bad
oil burning issue
not worth it bro
oil burning issue
not worth it bro
whiteknightef
Mar 30, 2004 10:00 AM
*BuMp*
