FUEL PUMP NOT PRIMING?
Somtimes i ll turn my key on and i wont here the pump turn on. Then the car wont start,it will only crank when i here the pump turn on so i have to turn the key on and off over and over agian.Whats the problem? do i have a short or somthing?
This morning it dident turn on and i had to wait like 30 mins.Could i have a bad pump?Is this why i have to set my idle higher? becuase my car will die if it falls to 1000 rpms? Whats the problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K-Drum »</TD></TR><TR><TD CLASS="quote">Main relay... you will probably notice that it happens mostly when the car interior is hot... if you open a window for 5 mins it works again... typical symptomes of a bad main relay. </TD></TR></TABLE>
From: I told you to wait in the truck in Texas, United States
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">REPLACE THE MAIN RELAY!! </TD></TR></TABLE>
Just fix the main relay. takes 10 minutes with a little bit of solder. Did mine 3 weeks ago and it saved me $50+ by not having to buy a new relay from honda.
http://www.markl.f9.co.uk/howt...y.htm
boosted_soul_94
Aug 5, 2006 09:57 AM
StreetEG
Jul 31, 2006 04:38 PM
