Shift solenoid
Old Jul 19, 2005 | 08:26 AM
LostAndFound's Avatar
Default Shift solenoid
Im having an issue with second, and only second gear popping out, and then the RPMs rise but I won't accelerate.
If I drive it normally, or floor it through the gears its all fine.
But when I leave it in second, hit a bump, take a turn hard with a little bumping it will pop out of gear. But the shifter doesnt actually go back to neutral, its kind of still in second I just have to clutch in and pull it back a bit.
I was thinking maybe a mount is bad, or its the clutch since the previous owner said he put a new clutch in himself, maybe an error, rather then the tranny going bad.
Another person said the shift solenoid, without elaborating at all. I can't find much on it besides it seems most of the poeple with automatics have it. Do manual trannies have this as well?
Or if you have any other suggestions what is wrong and why please post up!
TIA
Old Jul 19, 2005 | 09:10 AM
tequilakid's Avatar
Default Re: Shift solenoid (LostAndFound)
The popping out of Second is becuase the syncro/slider is going bad.
I've never heard of a 'Shift Soleniod' on a manual tranny car.
Old Jul 19, 2005 | 10:34 AM
but if a syncro is going bad wouldnt it grind at all too, absolutely no grinds going in second
jaydem7
12
Sep 2, 2007 05:12 PM
DSRxGOOMPA
Jul 19, 2007 02:20 AM
Demonis
Honda Civic (2006 - 2015)
Mar 24, 2007 09:37 AM
MugenGTR
Apr 12, 2006 09:09 AM
flukeDC4
Jan 15, 2005 06:41 PM
