greddy emanage ultimate question
Old Jul 18, 2005 | 10:37 PM
elrandeeto's Avatar
Default greddy emanage ultimate question
i did a search and couldnt find anything about the greddy e manage ultimate .
Ive read numerous post about people not thinking to highly of emanage since ive been a member . Today i visited there site and saw a new edition is out . i was just wondering if this sounds pretty good or people know from experience that its better than the first and worth the money . Im thinking about gettin it when i finish piecing together my turbo kit for my ls crx .
Old Jul 19, 2005 | 06:59 AM
elrandeeto's Avatar
Default Re: greddy emanage ultimate question (elrandeeto)
bump
Old Jul 19, 2005 | 07:20 AM
purplecrx's Avatar
I've heard the same negative comments, but personally I think i'm going to use one. People say to just get it tuned, but tuning is rather expensive as well. I'm just going w/ a GReddy turbo kit that includes the E-Manage. The Ultimate looks awesome though, especially w/ two storable tunes. So you can have a tune for pump and race for example. Don't listen too me too much, as I have no first hand experience! Goodluck with your setup, as I'm looking to do the same w/ my SOHC.
Old Jul 19, 2005 | 07:26 AM
elrandeeto's Avatar
Default Re: (purplecrx)
ya i liked to two tunes available on ot also
Old Jul 19, 2005 | 11:26 AM
elrandeeto's Avatar
Default Re: (elrandeeto)
http://www.greddy.com
The GReddy e-manage Ultimate was engineered to preserve the best features of the original e-manage (an economical price, the use of existing sensors, the ability to easily alter stock settings, & the vast compatibility for most Japanese performance vehicles), while advancing new innovations in piggyback engine control management. Although the external physical dimensions are the same, the Black-Chrome Ultimate has an increased number of input and output ports along with new built-in adapters, to add a number of new options.
In addition to standard e-manage airflow-based adjustments, the Ultimate version includes new and upgraded features. Included is a PC-based Ultimate Support Tool software CD, with an easy-to-use Parameter Set-up, tab menu format and speedy USB communication. Ultimate has improved direct Map control for adding and subtracting Fuel and Ignition. The ability to switch between 2 preset tuning Maps (i.e. Street or Race program) via externally mounted toggle switches. There are Maps for Individual cylinder adjustment for both Fuel and Ignition. There are also options to convert injection and ignition systems (i.e. group or sequential injection and group or individual fire ignition.) An Airflow Output Map option even allows for airflow meter elimination. And when used with a wideband A/F Meter, the Air Fuel Target Map can self-tune an Injector base tuning Map, to speed up initial tuning. There are also built-in Boost, Rev and Speed Limiter-Cut features. To create super smooth operation, there are various fine tuning Correction Maps to adjust for Throttle Acceleration, Vehicle Speed, Water Temp, Intake Temp, Auto Trans Shift, Anti Engine Stall, and Idle. To further aid in tuning, e-manage Ultimate's improved integrated Monitoring, Map Tracing and Datalogging features far exceed any other piggyback controller on the market. Even when not connected to the software, 8 channels of datalogging (at 20msec intervals) can be recorded and stored to be reviewed later. With the Support Tool connected, over 30 channels can be covered. Other new features include: Improved RPM recognition, Warning Settings, Password Protection for individual tuning Maps, NVCS (Nissan), VTEC (Honda), O2 Feed-back, Clean Fouled Plugs, and numerous others in future updates.
Ideal for optimizing and fine-tuning for performance products like Exhaust, Air Intake, Intercoolers, Boost Controllers, and Turbochargers, the e-manage Ultimate fills the gaps between conventional piggyback and expensive stand-alone engine managements.
GreddyEGSi
Jun 7, 2019 05:37 PM
1JDMDOMINICAN
Feb 10, 2006 11:47 PM
elrandeeto
Jul 20, 2005 12:30 AM
97CWITR
Dec 5, 2004 04:40 PM
JDM_EH2
Jan 31, 2004 07:22 PM
