CAR not starting...LOOK HERE and Help if you can. TIA
Battery is fine; ACC's comes on. When the key is turned to start... the engine does not turn over. No sound what so ever. No clicking or anything; dead silence.
Also, I can Push start the car. Thats how I got her home.
Car has had problems in the past were the fuel pump would NOT work and I would have to turn the key on and then off again and again until the fuel pump started. I know this has happened with other Integra's mainly DAs.
So, could it be the main-relay, the starter or my Ignition switch?
Please post comments. Thank you.
EDIT: Has anyone had this same issues with there integra?
Modified by C-speed Ricer at 12:18 AM 7/19/2005
Well when i got to the last line of your post you took the words outta my mouth.
"main-relay, the starter or my Ignition switch"
Those are my best guess, if it was just the starter it would kill the ACC during rollin the key to start. Im thinking it has more to do with the switch/tumbler because it doesnt cut off ACC power and click.
hmmmm... just read another thread and the similiar things were happening. Post were made about testing for voltage and the starter. But how would one test the ignition switch? I may just replace the main to stop the issues with the fuel pump.
Okay then, start with the easy stuff like checking for power at the starter solenoid with a test light or multimeter while someone is trying to crank.
As i've been searching for the last few hours I've found what to test. Just curious. does the starter have a relay? can't find any info on that.
I believe the starter is kind of like its own relay... when the plunger pushes it connects the ground internally to give the motor power to spin.
Even when its bad it will usually click, but not roll.
Im not sure if there is another relay for it.
If you want to look through a helms to find it-> http://www.redpepperracing.com...a-FSM
Hope you get it workin soon...
Yeah, me too. Push starting my car is getting a little old. But hey, I just say "Its a race kaa, it dont have a starter." LOL.
STARTER CONTACTS. what type of starter is it? nippondenso?
you can replace contacts in some, and others you're just **** outta luck.
bad igntion switch, check it by doing this, have someone turn it into the start position, check the spade terminal, on the starter to see if you are getting the signal, if you are not getting the signal the ignition switch is bad
Thanks to Mike K, Ill be trying a number of things to figure this out. Thanks for all the input guys, its really appreciated. (SHAMELESS PLUG) And don't forget to check out http://www.IMPORTCLASSIFIEDS.com for any parts you may need.
machaux
Nov 27, 2016 01:55 PM
