overheating at low rpm only....
Old Jul 18, 2005 | 06:18 PM
hotimportcrx's Avatar
Default overheating at low rpm only....
my b16 turbo only overheats at low rpm.....if i driving in bumper to bumper traffic i start overheating then if i decide to rip it cuz its clear the temp goes down ...this is only in taffic i overheat...i have a fullsize radiator with a pusher fan....and i have no thermostat.....so i dont know anymore...could this be the water pump and is there anyway to check it before i go out and buy one and then that not be the problem....HELPPPPPPPPPPPPPPPPPPp
Old Jul 18, 2005 | 06:22 PM
Skinflute22's Avatar
yeah take out the pump and look if the propeller is gone then get a new one if its okay then something else is wrong
Old Jul 18, 2005 | 06:24 PM
mntuner2's Avatar
Default Re: overheating at low rpm only.... (hotimportcrx)
Buy a Honda Pump! Even if ya gotta eat ramen for a couple days. Better to do it right the first time then do it twice. 2cents
kulangot's Avatar
put the thermostat back in...when your not moving its putting hot coolant in your engine..
Old Jul 18, 2005 | 06:28 PM
Default Re: overheating at low rpm only.... (kulangot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulangot &raquo;</TD></TR><TR><TD CLASS="quote">put the thermostat back in...when your not moving its putting hot coolant in your engine..</TD></TR></TABLE>
wow that actually sounds logical but idk...why do people say u cool better with no thermostat?
Old Jul 18, 2005 | 06:31 PM
mntuner2's Avatar
Because the thermostat is a physical body. It will resrict flow if you jam it inside a pipe. You may not warm up though in cold weather.
Old Jul 18, 2005 | 06:32 PM
kulangot's Avatar
don't no...i had mine out before and at a stop it would get hot but when i was driving it was cool...but it did that only in the summer when it was real hot out...so i put it back in (honda oem) and its great now..
Old Jul 18, 2005 | 06:49 PM
Bunger's Avatar
Take the timing covers off and see if the water pump is weeping. You should really put your t-stat back in also, and if it doesn't freeze where you're at, lower the % of coolant in you radiator (go to about 25% coolant) and run Redline Water Wetter (reguardless of freezing temps), this will increase your cooling capacity a good deal.
Old Jul 20, 2005 | 11:51 AM
mntuner2's Avatar
Default Re: overheating at low rpm only.... (mntuner2)
I'm probably wrong. I guess the slightly higher pressure could make the pump perform better. Yeah, mine runs pretty cool with it in. Damn cold winters here.
Old Jul 20, 2005 | 12:41 PM
Zeppelin's Avatar
Are you sure that your fan is working. The only difference between sitting in traffic and going at freeway speeds is the amount of air moving over the radiator. Unless you can sit in traffic at 4000rpm and it does not overheat, then it might be an impeller issue with the pump.
Old Jul 20, 2005 | 12:46 PM
salbaje's Avatar
check if fan is working otherwise put back the thermostat and bleed it properly
turbo-crx
May 14, 2008 07:04 PM
WhiteOnRice
11
Nov 30, 2007 12:59 PM
JDM EJ1 95
Feb 18, 2005 07:48 AM
CRXed
11
Jun 24, 2004 10:13 PM
af97civic
May 29, 2003 01:13 PM
