450cc dsm injectors
ok i have a 93 ls motor and a t3/t4 in a 89 civic h/b and i want to go wit bigger injectors like the dsm 450cc,does anybody have like a write up or like can tell me how to get them to work,and what u need thanks
hmm i have no idea if you really need a ecu upgrade in order to get the DSM injectors to work....i have re-searched them "SOME-WHAT" and heard just that the ecu helps but isnt needed for them to work....i might be wrong..i just know that you have to re-wire a RESISTOR BOX from a older honda / acura and that should be just fine...WELL...with that all said...i will post you a link to my current problem dealing with the whole DSM injector BS when i re-edit this reply...good luck...-swift
sure u can run dsm on a stock ecu but ur cars gonna run like ****. u need to chip the ecu and run uberdata,crome ,hondata,or neptune in order to scale the fuel maps for the larger injectors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Miller »</TD></TR><TR><TD CLASS="quote">you're also going to need a resistor box and injector plugs. ebay is your friend.</TD></TR></TABLE>
well the easy was in which i read to by-pass the injector plugs if you have a OBD1 setup is to melt the hard plastic on the top of the blue top DSM's and they will fit right in...as i did with mine
anyone know where i can get a basemap for cheap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr_b20x2 »</TD></TR><TR><TD CLASS="quote">
anyone know where i can get a basemap for cheap?</TD></TR></TABLE>
if you have an OBD1 setup all you have to do is take a razor and shave/cut the small knotch in the DSM injectors off and the clips snap right on
anyone know where i can get a basemap for cheap?</TD></TR></TABLE>if you have an OBD1 setup all you have to do is take a razor and shave/cut the small knotch in the DSM injectors off and the clips snap right on
if your running an 89 ecu your gonna need something like turboedit or zdyne.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceFed Coupe »</TD></TR><TR><TD CLASS="quote">where can i get uberdata or crome?</TD></TR></TABLE>pgmfi.org
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tannerLSt »</TD></TR><TR><TD CLASS="quote">
if you have an OBD1 setup all you have to do is take a razor and shave/cut the small knotch in the DSM injectors off and the clips snap right on</TD></TR></TABLE>
i used a hot butter knife...lol...
keebler65
May 1, 2003 08:02 AM
Peter K
May 1, 2002 10:02 PM
