450cc dsm injectors
Old Jul 18, 2005 | 03:34 PM
hatchyboy89's Avatar
Default 450cc dsm injectors
ok i have a 93 ls motor and a t3/t4 in a 89 civic h/b and i want to go wit bigger injectors like the dsm 450cc,does anybody have like a write up or like can tell me how to get them to work,and what u need thanks
Old Jul 18, 2005 | 03:37 PM
SwappedTURBOegg's Avatar
Default Re: 450cc dsm injectors (hatchyboy89)
search
Old Jul 25, 2005 | 11:11 AM
Default Re: 450cc dsm injectors (B16 delSlow)
does anybody have any links on how to
Old Jul 25, 2005 | 11:26 AM
NotPhilTran's Avatar
http://www.homemadeturbo.com/t...ctors/
there. have at it.
Old Jul 25, 2005 | 01:19 PM
EgLsTurbo's Avatar
Default Re: 450cc dsm injectors (NotPhilTran)
your gonna need hondata for 450cc injectors
Old Jul 25, 2005 | 02:37 PM
Jizzmaster Zero's Avatar
(banned)
Default Re: 450cc dsm injectors (EgLsTurbo)
Hondata is overpriced, don't be dumb.
Get uberdata (free)
or Crome (free trial, $149 for full version)
Old Jul 28, 2005 | 12:55 PM
ok i i just heard there was another thing like hondata but better and it starts wit an N i think does anybody know what that is
Old Jul 28, 2005 | 01:12 PM
village_idiot's Avatar
neptune
Old Jul 28, 2005 | 05:54 PM
thats it i could not think of it at all
thanks,do u know if it is good?
Old Aug 8, 2005 | 05:15 PM
gsr_b20x2's Avatar
Default Re: (hatchyboy89)
hmm i have no idea if you really need a ecu upgrade in order to get the DSM injectors to work....i have re-searched them "SOME-WHAT" and heard just that the ecu helps but isnt needed for them to work....i might be wrong..i just know that you have to re-wire a RESISTOR BOX from a older honda / acura and that should be just fine...WELL...with that all said...i will post you a link to my current problem dealing with the whole DSM injector BS when i re-edit this reply...good luck...-swift
Old Aug 8, 2005 | 11:38 PM
boosted k20's Avatar
Default Re: (gsr_b20x2)
sure u can run dsm on a stock ecu but ur cars gonna run like ****. u need to chip the ecu and run uberdata,crome ,hondata,or neptune in order to scale the fuel maps for the larger injectors
Old Aug 8, 2005 | 11:42 PM
Dr Miller's Avatar
you're also going to need a resistor box and injector plugs. ebay is your friend.
Old Aug 9, 2005 | 09:40 AM
gsr_b20x2's Avatar
Default Re: (Dr Miller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Miller &raquo;</TD></TR><TR><TD CLASS="quote">you're also going to need a resistor box and injector plugs. ebay is your friend.</TD></TR></TABLE>
well the easy was in which i read to by-pass the injector plugs if you have a OBD1 setup is to melt the hard plastic on the top of the blue top DSM's and they will fit right in...as i did with mine anyone know where i can get a basemap for cheap?
Old Aug 9, 2005 | 11:42 AM
tannerLSt's Avatar
ME LOVE U LONG TIME
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr_b20x2 &raquo;</TD></TR><TR><TD CLASS="quote">
well the easy was in which i read to by-pass the injector plugs if you have a OBD1 setup is to melt the hard plastic on the top of the blue top DSM's and they will fit right in...as i did with mine anyone know where i can get a basemap for cheap?</TD></TR></TABLE>
if you have an OBD1 setup all you have to do is take a razor and shave/cut the small knotch in the DSM injectors off and the clips snap right on
Old Aug 10, 2005 | 12:33 PM
ForceFed Coupe's Avatar
Default Re: (tannerLSt)
where can i get uberdata or crome?
Old Aug 10, 2005 | 12:53 PM
ramennoodles's Avatar
Default Re: (ForceFed Coupe)
if your running an 89 ecu your gonna need something like turboedit or zdyne.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceFed Coupe &raquo;</TD></TR><TR><TD CLASS="quote">where can i get uberdata or crome?</TD></TR></TABLE>pgmfi.org
Old Aug 12, 2005 | 12:38 AM
gsr_b20x2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tannerLSt &raquo;</TD></TR><TR><TD CLASS="quote">
if you have an OBD1 setup all you have to do is take a razor and shave/cut the small knotch in the DSM injectors off and the clips snap right on</TD></TR></TABLE>
i used a hot butter knife...lol...
dnbruut
Feb 15, 2008 08:18 AM
Dawson21
Jun 9, 2004 04:41 PM
keebler65
May 1, 2003 08:02 AM
tsi_turboawd
Mar 27, 2003 12:19 PM
Peter K
May 1, 2002 10:02 PM
