STUCK!!!!!!!!!!!!
Old Jul 18, 2005 | 02:59 PM
LOGICx420x's Avatar
Default STUCK!!!!!!!!!!!!
I'M NEW TO THIS SITE AND I NEED HELP ON MY 93. I GOT A SMALL ELECTRICAL PROBLEM, I GOT NO GAUGES, NO POWER WINDOWS, AND I CANT GET MY CAR OUT OF PARK, NOW I HAVE TESTED THE IGNITION SWITCH, AND FUSES, I CAN GET MY CAR OUT OF PARK BUT I GOT TO DO IT BY HAND, AND WINDOWS ROLL DOWN IF I RUN A WIRE FROM BTTRY TO CPU, THEN THEY ROLL DOWN, I DON'T TAKE IT TO A MECHANIC CUZ I USUALLY DO THE WORK MYSELF, BUT I'M STUMPED ANY TAKERS.......
Old Jul 18, 2005 | 03:18 PM
RiceRocketDave's Avatar
Default Re: STUCK!!!!!!!!!!!! (LOGICx420x)
First of all stop typing in caps.
You need to recheck all your fuses. Take each one out individually if need be.
Also has there been anything done to the car to cause this problem?
Old Jul 18, 2005 | 05:55 PM
NAiL05's Avatar
Recheck your fuses then check your grounds...and check your brake switch.
Old Jul 19, 2005 | 01:31 PM
LOGICx420x's Avatar
Modified by LOGICx420x at 3:33 PM 7/19/2005
Old Jul 19, 2005 | 01:56 PM
Im not being an *** about anything. Im just saying that it is really annoying when people type in caps, and anyone else on this forum will say the same.
I have had problems before and I have overlooked a blown fuse. That is why I said to double check the fuses.
Now to my other question.....Was there anything done to the car to maybe cause this problem. Like a new cd player install or something else electrical.
Also what did you check on the ignition switch?
Just trying to help out and give you some advice. You don't have to be a complete ******* about it
Old Jul 19, 2005 | 01:59 PM
i20ar's Avatar
your dumb to think that you'll get any answers responding like that... is there an anti theft device on your car maybe its interfering
Old Jul 19, 2005 | 09:54 PM
deserthonda's Avatar
all 3 things i dont think share the same fuse ..i would look for a same ground they might share or .... you got separate problems .........did all 3 things happen together???
jump the wires at brake switch see if you can get car out of park if so then you got different problems
igone916
Jun 25, 2007 09:05 PM
wmflyfisher
Feb 15, 2007 05:47 PM
.David
Mar 8, 2005 12:48 AM
zcivicz
Nov 30, 2004 04:16 PM
Heinz57
Mar 21, 2003 12:33 PM
