Laggy 2nd and 3rd gear after startup
Old Jul 18, 2005 | 12:49 PM
Bigmojoj27's Avatar
Default Laggy 2nd and 3rd gear after startup
It only does this for the first time that I shift into those gears after the car has been sitting for a while. I drive a 95 coupe and whenever I shift into 2nd gear, I get to about 2K and all the sudden it starts "stumbling" and it feels like the motor/tranny is sputtering along and then it kinda snaps out of it at about 2300. I shift into 3rd and it starts to do the same thing. For the rest of the drive, everything feels perfect. Anyone had this problem or know what could be causing this?
Old Jul 18, 2005 | 02:16 PM
Bigmojoj27's Avatar
Default Re: Laggy 2nd and 3rd gear after startup (Bigmojoj27)
BUMP for help
Old Jul 18, 2005 | 08:14 PM
Bigmojoj27's Avatar
Bumpity Bump
Old Jul 18, 2005 | 08:19 PM
moto1320's Avatar
Look for oil in your distributor cap.
Old Jul 18, 2005 | 08:35 PM
Bigmojoj27's Avatar
Default Re: Laggy 2nd and 3rd gear after startup (moto1320)
Would that really be causing it. Ok, I'll look tomorrow? BUMP for any more ideas in the mean time.
Old Jul 18, 2005 | 08:48 PM
moto1320's Avatar
If your distributor base seal is seeping oil into the cap then it will coagulate when cold and cause stuttering for a short time and then go away as the head warms up and the oil softens. While your in there you also get to inspect he othe culprits, the cap and rotor. Well worth the time it takes to unscrew 3 screws.
Spark plug wires that are going out often times also have a low/mid RPM spot when they stumble and then smooth out.
Old Jul 19, 2005 | 04:19 PM
Bigmojoj27's Avatar
I checked the dizzy, and there was very slight traces of oil lining one of the screw holes. I believe this is from when I blew my head gasket. I've read about replacing the o-ring, and thats it's really cheap and a good house keeping task, so I think I'll do that sometime next week. But BUMP for any more ideas? Is it possible that that it's something with transmission or anything like that?
Old Jul 20, 2005 | 08:28 PM
Bigmojoj27's Avatar
BUMP
jdmjunkieXL
27
Feb 22, 2007 09:24 AM
hondatuner20
May 30, 2006 07:19 AM
lude98SH
Dec 1, 2005 08:07 PM
AznInvasion
Aug 24, 2002 06:15 AM
