what injector clips for 780cc injectors?
what injector clips can i use for precision 780cc injectors. the obd1 clips don't fit, just wondering if i need to get some pre obd injector clips or maybe dsm injector clips or if i can modify my existing obd1 injectors clips to fit on these. btw these are peak and hold injectors. thanks.
wha kinda car do u have, i have a h22a, and the stock clips worked fine for me.....
i also have the same precision 780cc's in there
they will indeed fit...you have to cut the inside of the injectors for the clips to slide in...use an exacto knife or razor blade....
btw they use obd 1 clips...and make sure you have a resistor pack in there before tryin anything w/ those
okay cool. yeah i knew about the resistor box. just didn't know if i could find some injector clips that didn't need modifying. what year injector clips are you using rudelude? thanks for the info.
Panoply
Jul 18, 2005 09:36 AM
