noises when turning
so i've started hearing this noise lately whenever i turn to the left. taking a slow left turn doesn't do it, i have to be pushing a little. i though maybe the axle was coming loose from the transmission, or the control arm was rubbing, but these all seem to be OK. it sound like a clunking noise, and i think it's coming from something that i spinning. i don't feel any jerks from the car, so it can't be a huge problem, and there are no visible sign of anything wrong from underneath either. anyone have any advice?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6racer »</TD></TR><TR><TD CLASS="quote">so i've started hearing this noise lately whenever i turn to the left. taking a slow left turn doesn't do it, i have to be pushing a little. i though maybe the axle was coming loose from the transmission, or the control arm was rubbing, but these all seem to be OK. it sound like a clunking noise, and i think it's coming from something that i spinning. i don't feel any jerks from the car, so it can't be a huge problem, and there are no visible sign of anything wrong from underneath either. anyone have any advice?</TD></TR></TABLE>
I just had this problem. My upper balljoint was gone, replaced that and that damn noise is still there. It is when I turn the wheel all the way to the left or right and it gets to the end of the wheel, I hear this PING noise like the "O" ring on the axle or the CV joint is popping out...but nothing actually breaks or pops out.
Not sure what it is now, I will have to get someone to turn the wheel while I crawl underneath to find out where the noise is coming from.
I also heard the noise coming from the rear end at the same time the front made a noise. More like a creaking noise, but it could just have been noise traveling through the car to the rear end....I hope
Hope this helps.
Hope this helps.
Guest
Posts: n/a
I have the same problem, EXCEPT the noise that I hear is a clicking noise when I am turning. I know it is coming from the right side, but I have no idea what it is. I was told by some people that it is prolly my CV joint but I havent had time to look at it nor have it fixed. If you or anyone else figure out what the problem is for sure...Then let me know that way I can look at mine and have an idea of what it is that might be wrong. Thanks! ~Anthony
mine is mostly at a dead stop, turning the wheels. the right side makes a loud ping sound, I just had the balljoint replaced so im not sure what mine is until I get underneath the car and have someone turn the wheels.
Sounds like a cv joint for the clicking noise when turning though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnthonyG2003 »</TD></TR><TR><TD CLASS="quote">I have the same problem, EXCEPT the noise that I hear is a clicking noise when I am turning. I know it is coming from the right side, but I have no idea what it is. I was told by some people that it is prolly my CV joint but I havent had time to look at it nor have it fixed. If you or anyone else figure out what the problem is for sure...Then let me know that way I can look at mine and have an idea of what it is that might be wrong. Thanks! ~Anthony
If you have clicking you need to go gen a new CV Joint, all your grease has leaked out of the boot and the joint has gone bad,
</TD></TR></TABLE>\
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MNsnowdaboy »</TD></TR><TR><TD CLASS="quote">Grease = answer </TD></TR></TABLE>
Yup and all the grease will be around the car somewhere in that area. I'll tell you that it'll suck messing with your suspension then all of a sudden you grab a pile of grease ****.
riceforlife
Suspension & Brakes
13
Dec 12, 2007 11:27 PM
GReddy SI
12
Jul 17, 2003 04:07 AM
