B16 OIL BURN QUESTION
I just recently had topped off my b16 with royal purple 5-30 on my 2000 EM1 last month.
now allready its below the second dot. i drive it 15 MILES A DAY but is it normal
for it to BURN OIL this quick (NO LEAKES AT ALL) MAYBE HIGH RPMS
Driving it hard will burn oil more quickly. Do you literally race all 15 miles you drive each day?
You should not be losing that much oil.
-Shane
You should not be losing that much oil.-Shane
YEAH about that many miles but i will admit that i drive and cruisE hard AT HIGH RPMS every now and then , I have my VTEC CONTROLLER SET AT 4500 WITH MY THROTTLE SET WIDE OPEN WIDE WHEN IT KICKS IN AS WELL WITH THE NARROW THROTTLE. More fuel at sacrifice
Don't set vtec that low
! It was set at 6200 from the factory for a reason, and anyone else on here will tell you the same thing. But like I said. The vtec pressure switch needs oil to activate, so when the oil gets low, the vtec will not work or will work erratically.
-Shane
! It was set at 6200 from the factory for a reason, and anyone else on here will tell you the same thing. But like I said. The vtec pressure switch needs oil to activate, so when the oil gets low, the vtec will not work or will work erratically.-Shane
YEAH no wonder my vtec has had a quiet transition for the past couple of days Forgot to mention that my chipped ecu was set at 5500
at 9000 rev limit ; BUT THANKS FOR THAT ADVIce. I set it @ 6200
I got to baby this motor more often
( A little trigger happy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yh23 »</TD></TR><TR><TD CLASS="quote">i thought EM1 si's vtec is 5500/5600rpm when stock?
I believe it was at 5500
There is absoluly no reason why your VTEC should be at 4.5k unless you have Dual Stage Intake Manifold. Other then that your VTEC should be around 5-6k Maybe more if you have some serious cams
My b16a used to use oil all the time. Drive it normal and see what happens. Like for example under 5 grand.
USDM B16A2 = 5400rpm vtec engagement
JDM B16A2 = 6100rpm vtec engagement
Having your's at 4500rpm will make you burn oil and also make your power band shitty.
I did switch to 5500 VTEC Engagement
and had started cruising below 5k I only had Done this 4500 vtec thing since i got my obx cam shafts which are replicas of the Jun3s and CTR cams With stiffer springs and racing retainers. I do understand that hiher RPMs=Stronger VTEC PULL {the more the marrier} NOW I HAVE TO BUY MORE OIL
10W 30 THIS TIME.
10W 30 THIS TIME.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M1-UNIT »</TD></TR><TR><TD CLASS="quote">I just recently had topped off my b16 with royal purple 5-30 on my 2000 EM1 last month.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M1-UNIT »</TD></TR><TR><TD CLASS="quote">FORGOT TO SAY THAT THIS WAS JDM B16A
10-4-1 COMP.</TD></TR></TABLE>
So, you have a 2000 Si with a JDM B16 motor swap? Doesn't make a whole lot of sense, but hey.
-Shane
-Shane
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 »</TD></TR><TR><TD CLASS="quote">
-Shane</TD></TR></TABLE>
I saw a 2000 Si on ebay with a LS swap LOL
on my com i beleive the vtec is from 5200 to 8600 why whould it be a problem if not 6200 for a reason? whould afternarket cam gears take up the difference in anything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M1-UNIT »</TD></TR><TR><TD CLASS="quote">obx cam shafts which are replicas of the Jun3s </TD></TR></TABLE>
Hope they don't grenade on you
OBX makes some shitty stuff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicky »</TD></TR><TR><TD CLASS="quote">
OBX makes some shitty stuff</TD></TR></TABLE>
Their muffler has lasted me, and it is deep.
-Shane
-Shane
tthomass
80
Nov 15, 2006 09:56 AM
