my shifter shakes!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 »</TD></TR><TR><TD CLASS="quote">my shift **** shakes at idle? do i need a new shifter bushing?</TD></TR></TABLE>
It's possible for the shifter to shake excessively if you have a worn bushing somewhere on the linkage. You should get under the car and check them out!
its pretty normal unless it shakes alot and vibrates. if so then check the bushings and also where the shifter connects to the change rod. check the bolt there and maybe tighten it up "jus a little bit"
if it shakes, shake it back.
just pickup energy suspension shifter bushing kit for your car. it will be the best $12 you will ever spend
kragen is your friend.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sir-s »</TD></TR><TR><TD CLASS="quote">if it shakes, shake it back.
kragen is your friend.</TD></TR></TABLE> yes!
You might need new bushings. Mine did that with the OEM bushings, being 10 years old. I replaced the with Energy Suspension polyurethane ones, no shake at all. Hardly noticeable.
jacoop86
10
May 23, 2006 11:53 AM
137
Jun 17, 2005 08:00 AM
BAZ
Jul 29, 2003 09:29 PM
