fuel and spark no start
Old Jul 17, 2005 | 09:13 PM
92hybrid+'s Avatar
Default fuel and spark no start
ctr motor in my eg has fuel pressure and and spark, why would it not start , also no oil pressure using gsr pickup, b20 oil case with ctr pump gear? cranks over fine only 60% to 80% on a compresion test.
Old Jul 17, 2005 | 11:42 PM
EG_intheworks's Avatar
Default Re: fuel and spark no start (92hybrid+)
u need fuel spark and TIMING. check ur plugs and wires/timing for dumb mistakes. I had my **** backward the other day felt like an ******* when I figured what it was.
Check the clearance between the bottom of the oil pan and the pick-up, if the clearance is too small can contribute to no/low oil pressure.
Just a bump though_
Old Jul 18, 2005 | 01:35 PM
92hybrid+'s Avatar
i pluged in my cx harness back in to see if i could even get it to start now it doesnt even crank just a humming noise behind the dash everything is plugged correct ?
Old Jul 18, 2005 | 01:38 PM
Dueceification's Avatar
The humming noise is your fuel pump. Just out of curiosity do you have proper grounding from the engine to the chassi of the car. If not it will try to turn over but wont start.
Old Jul 19, 2005 | 07:58 AM
92hybrid+'s Avatar
is it possable to use b20 non vtec cam gears to retime the motor since i did the timing with aftermarket gears . or use stok gsr's?
Old Jul 19, 2005 | 11:12 AM
B-twentyVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hybrid+ &raquo;</TD></TR><TR><TD CLASS="quote">is it possable to use b20 non vtec cam gears to retime the motor since i did the timing with aftermarket gears . or use stok gsr's?
no.. don't do that!!!
Old Jul 19, 2005 | 03:06 PM
becoming's Avatar
Default Re: fuel and spark no start (Mr_WETTY)
I put a B20 in my friend's 2k civic a few weeks ago and had the same problem....fuel and spark, no cranking going on! Believe it or not it was the distributor..was sending spark, but would not crank the car! Changed the distributor, and walla! FIRE. may work for you too, just something else you could check, GL.
Old Jul 19, 2005 | 03:22 PM
JDM-97CX's Avatar
Default Re: fuel and spark no start (EG_intheworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG_intheworks &raquo;</TD></TR><TR><TD CLASS="quote">u need fuel spark and COMPRESSION .</TD></TR></TABLE>
He just said that hel only made 60 - 80% on a compression test and all you think of is timing? You are not going to be able to fire that engine with a huge compression leak.
Old Jul 19, 2005 | 03:38 PM
xEnderx's Avatar
Default Re: fuel and spark no start (JDM-97CX)
Werd. With that big of a mechanical problem....well lets just hope you enjoy tearing the motor down and fixing whatever is wrong with it.
Old Jul 19, 2005 | 09:55 PM
92hybrid+'s Avatar
hahaha it was the timing the moter runs cherry after not running for a year first swap and every thing is great no problems what so ever hahahahahahah
mikeyg1995
Apr 22, 2012 07:38 PM
Jdmbryan
Dec 19, 2011 06:23 AM
free99
Mar 18, 2008 10:52 AM
EKris
Mar 4, 2007 08:37 AM
pbizzlegsr
Aug 27, 2004 08:55 AM
