00 Si Turned Off While Driving And Wont Start Back Up
Long Story Short; I was driving,the car shut off,and i attempted to start it back up and it just cranked but didnt turn over, i tried checking the fuses under the dash and engine bay but theyre all good, i even replaced the one for the fuel pump just incase. when i crank it , the ebrake light blinks when i turn the key, it wants to start but just dont. what else should i look for?
Re: 00 Si Turned Off While Driving And Wont Start Back Up
Does the fuel pump prime?
Is there bright white spark at all 4 spark plugs?
Did the timing belt snap or skip a tooth or two?
work it from the begining. i would check spark. pull a plug and shock a friend when u try o turn it over , if ur friend gets shocked then check fuel, i prefer to start to un bolt the feed banjo bolt from the fuel rail. if u have pressure then it is most likely ok . i found when the pump goes out the rail will have no pressure. then check oil and coolent for a milky look. all good then pull the upper timing cover check that the timing belt is tight if kinda loose then u could have skipped a tooth or 2. idk good luck .. and can u be a little more specific on what happened.
got the problem figured out guys :thumbsup: there was a unplugged wire on my harness just touching against others and it kept blowing my fuse under the hood, thanks a lot guys.
zoopreme
27
11-09-2009 09:05 AM
