Want to Buy Want to Trade/Want to Buy
WTB: B SERIES MOTOR MOUNTS/BRACKETS FOR AN EK!!!! CASH IN HAND!!!
Old Jul 17, 2005 | 08:54 PM
crazykid9137's Avatar
Default WTB: B SERIES MOTOR MOUNTS/BRACKETS FOR AN EK!!!! CASH IN HAND!!!
Hey everyone im in desperate need of all the b series motor mounts/brackets i need to fit my ls swap into my 96 ek coupe...
I have read I could and should use the oem 2000 civic si mounts and brackets but am not 100% sure. Im swapping in a full b18b1 engine and tranny so if you have the mounts and brackets I need PM ME ASAP with a good price shipped to 33029....
Thanks
Old Jul 17, 2005 | 09:09 PM
Default Re: WTB: B SERIES MOTOR MOUNTS/BRACKETS FOR AN EK!!!! CASH IN HAND!!! (96ekcivic4u)
bump...
Old Jul 17, 2005 | 09:16 PM
bump cmon people...
Old Jul 18, 2005 | 12:15 AM
95 integra's Avatar
I have the rear mount and bracket you need.
Old Jul 18, 2005 | 07:29 AM
klungemonger's Avatar
I JUST completed putting a B18B into my 98 hatch. Here is the list of what you need:
Notes: All stock rubber mounts in the car you can keep, so don't pay for any of that. Also, the top trans bracket which attaches by the shock tower you can reuse from your D-series.
1) 99-00 Si rear trans bracket
2) 99-00 Si driver side upper block bracket. It's the part that bolts under the timing cover...the black stamped part that attaches to the rubber you can keep from your D-series also.
3) 99-00 Si front lower trans bracket (possibly other B-series ones will work also.
4) P7J a/c bracket - this will allow you to mount your stock a/c compressor the the B-block without having to discharge the system or having to buy a B-series compressor.
Hope this helps and saves you money and hassle!
Old Jul 22, 2005 | 05:36 AM
Default Re: (klungemonger)
Thanks for the help
Old Jul 22, 2005 | 06:11 AM
fracas's Avatar
Contact , CTRbOy
he has what you need cheep.
Old Jul 22, 2005 | 08:55 AM
OK everyone I have seemed to have gathered up all the brackets i need minus the 96 del sol ac bracket, but im not worried about it too much...
Anyways, my question now is, that my 96 civic ex is an AUTOMATIC right now and i have all the parts such as the pedal assembly, master clutch cylinder, 5 speed tranny and new motor, clutch lines, and linkage.... so will my automatic civic ex front tranny rubber MOUNT (not bracket as I actually have the Integra front bracket) work and bolt up even though its not auto anymore???
Thanks
PS. will the integra front tranny bracket work on my swap by the way??
Thanks everyone for ur help
Old Jul 22, 2005 | 01:50 PM
Teg front tranny bracket will work alright, rubber mount will also still be fine.
Don't forget the clutch slave cylinder too!
Old Jul 22, 2005 | 11:33 PM
the clutch slave cylinder is still on my tranny i bought a full ls swap with tranny and all...
Old Jul 22, 2005 | 11:35 PM
Default Re: (96ekcivic4u)
ok so basically i got the 2000 si driver side bracket, i got a 2000 si rear tranny bracket and i have the integra front tranny bracket and i can use my 96 ek bracket for the bracket on the top of the tranny and re use all my stock civic mounts correct?
So i got everything so far...
Anything else im missing before i start???
Thanks
Civic082382
Nov 19, 2009 12:22 PM
ViSiONxBoY
19
Aug 8, 2009 04:37 AM
allen7-civic
Dec 25, 2008 06:30 AM
happyabortion
Mar 24, 2008 06:42 PM
