Chipped Piston/Scuffed Cylinder Wall What Next?????
Awhile back i chipped off a peice of my #4 piston and scuffed the #4 cylinder wall.
Here are some pics:
This leaves me with several options
Things to Keep in Mind:
I am on a $2500 budget for the bottom end build.
This is my daily driver.
My goal is around 300-325 daily driven whp.
Which option should i go with?
Here are some pics:
Rebuild the block, go with 81.5mm pistons and GE rods. Should be around $1000 to rebuild it. I have pistons/rods on mine, daily driver and over 460whp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ArinX »</TD></TR><TR><TD CLASS="quote">im with both of them
and im with you
</TD></TR></TABLE>and im with you
sleaves =1000
pistons/rings cp 81.5mm 9:1 comp 500
eagle rods _=325
acl bearings 90 dollars
arp headstuds=100
total is still under 2500 and if you wanted to im sure you could get a deal on better rods and shoot for 600whp if your turbo setup is appropriate
eagle rods _=325
arp headstuds=100
The 2500 is also including the bore and hone/ hot tank and step deck, oem main bearings, oem thrust washers, oem head gasket, type-r oil pump, and shortblock assembly. Not that those things make it add up to 2500 but just letting you know those are part of the deal.
trooper0641
28
Oct 25, 2004 09:46 AM
