need help removing corners
Old Jul 17, 2005 | 12:48 PM
LudeJdm's Avatar
Default need help removing corners
one of my bulbs blew for my passenger corner lights...but when i tryn removing the corner it wont come out...ive removed the 2 screws already...is there like a tab to push down or should it juss slide out...because it wont slide...need help....
Old Jul 17, 2005 | 01:14 PM
superbeastcrx's Avatar
Default Re: need help removing corners (envysionHATCH)
just slide it foward and it should come out. if it doesnt it just means the little rubber bushings that keep it from vibrating are all dried up.
Old Jul 17, 2005 | 01:19 PM
LudeJdm's Avatar
Default Re: need help removing corners (superbeastcrx)
how do i undry them....do i spray it with something???
Old Jul 17, 2005 | 01:21 PM
Ass$nyper's Avatar
Pirate General...YARRRR
undry?
Old Jul 17, 2005 | 01:23 PM
LudeJdm's Avatar
Default Re: need help removing corners (Ace$nyper)
is there a way to lube it up????so it can slide out easier???
Old Jul 17, 2005 | 01:24 PM
Ass$nyper's Avatar
it should just come right out i dunno what yours is stuck on just be careful look around and give a yank if need be
Old Jul 17, 2005 | 01:25 PM
LudeJdm's Avatar
i dont want to crack the lens....
Old Jul 17, 2005 | 01:33 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Here is a shot of the backside of it:
The two tabs are what hold it in,It snaps into place..
Old Jul 17, 2005 | 01:46 PM
the niz jiz's Avatar
Default Re: need help removing corners (88DXCRX)
take a flat head and pop it out, should break anything
Old Jul 17, 2005 | 01:59 PM
bucketheadCRX's Avatar
Default Re: need help removing corners (N.O.R.E)
sometimes i have to "slightly" jiggle the lens up and down while pulling outwards to get the lens to release from the clip..be careful and good luck(go slow and think..pull straight out..not side to side at all or the clip might break)
Old Jul 17, 2005 | 03:23 PM
trrbl1bmx's Avatar
KY warming liquid will do the trick!
No. but just play with it with a flat head screwdriver.
Old Jul 17, 2005 | 04:00 PM
Ass$nyper's Avatar
Default Re: (ilovemyef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilovemyef9 &raquo;</TD></TR><TR><TD CLASS="quote">KY warming liquid will do the trick!
No. but just play with it with a flat head screwdriver.</TD></TR></TABLE>
that **** burns my **** if putting in somthing warm
maybe be worth while if you fucked corpses but when the ***** is alive its warm enough.
Old Jul 17, 2005 | 07:18 PM
trrbl1bmx's Avatar
Default Re: (Ace$nyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ace$nyper &raquo;</TD></TR><TR><TD CLASS="quote">
maybe be worth while if you fucked corpses but when the ***** is alive its warm enough.</TD></TR></TABLE>
hahaha
Old Sep 18, 2005 | 11:19 AM
TealCivic93's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envysionHATCH &raquo;</TD></TR><TR><TD CLASS="quote">one of my bulbs blew for my passenger corner lights...but when i tryn removing the corner it wont come out...ive removed the 2 screws already....</TD></TR></TABLE>
which two screws... i've removed the top one, but where is the other?
Old Sep 18, 2005 | 11:52 AM
never mind, on my 90si their was just one screw and then i just played with it and it came out.
maraster
May 25, 2019 10:56 AM
ken9
Dec 29, 2008 11:23 AM
sleeperteg
Aug 17, 2005 08:38 AM
civicSIracer96
Nov 6, 2003 08:43 PM
Sassafrass
Apr 24, 2003 11:40 AM
