Where to get the "L" threaded thing for oil line
Old Feb 17, 2002 | 11:15 AM
Ri5e's Avatar
Default Where to get the "L" threaded thing for oil line
So I bought a new turbo and now I need that "L" thing that screws into the oil feed hole on the turbo unit. And then I connect the oil line into the other end.
Was wondering if I can get that at Home depot?
haha
Old Feb 17, 2002 | 11:59 AM
b18bturbo's Avatar
Default Re: Where to get the "L" threaded thing for oil line (BG Boost)
are you talking about the T in the back of the block. whre the oil pressure unit is/.
Old Feb 17, 2002 | 12:10 PM
G's Avatar
G
The -6an (-8an) to 1/8npt (or 1/4"npt) adaptor? Depending on the kit, you'll probably have to go to a fitting/air compressor/hydraulic hose place with your oil line. I am using hard lines for my oil feed and most small compression and flare fittings can be found at Home Depot. I had trouble finding the an fitting for my drag equipped oil feed line.
Old Feb 17, 2002 | 12:44 PM
Giuseppe's Avatar
90 degree elbow..???
that 'thing'..?????
Old Feb 17, 2002 | 02:20 PM
93LSivic's Avatar
Heh, funny I have one right here in front of me. Ofcourse you will need a -4AN fitting for it to connect to the oil feed line.
Its an 1/8" FIP to MIP elbow, then you gotta put the an fitting on it.
You can buy the 90degree fitting that has the 1/8" pipe thread to the -4AN thread from anyone that sells the earl's or aeromotive fittings.
eg6_lsi
Mar 18, 2004 04:46 PM
redboost10
Oct 22, 2003 06:56 PM
MikeMAN
Jul 2, 2002 09:25 PM
