motor swap without engine lift?
Old Jul 17, 2005 | 10:26 AM
civiccoupe94's Avatar
Default motor swap without engine lift?
my dx motor on my 94 coupe is about to turn bad, so im lookin for another b7 for cheap. i love the 38 mpg and still match up with some v6's. anyways how much does the longblock weigh? and will 5 guys be able to do the job without a engine lift? like take off valve cover, oil, headers, IM, it should be pretty light right?
were thinkin of jacking the car really high and then put the motor under it, then pull the motor up to its place under the hood. thanks guys
Old Jul 17, 2005 | 10:54 AM
hondaeg8's Avatar
Default Re: motor swap without engine lift? (civiccoupe94)
i do swaps like that all the time. i never use an engine lift.
i think its easier. you will probably need at least one other person to help you.
Old Jul 17, 2005 | 10:55 AM
komat's Avatar
Default Re: motor swap without engine lift? (hondaeg8)
.... read the faq b4 asking questions
Old Jul 17, 2005 | 11:21 AM
Stoich EG2's Avatar
Default Re: motor swap without engine lift? (komat)
What i usually do is take off the front wheels and put a creeper under my motor. i then proceed to lower the car til the motor is resting on the creeper (DO NOT LET THE CAR REST ON THE CREEPER, JUST THE MOTOR). keep the jack holding the car in the same position then, unbolt all the mounts and anything else that is holding the motor there. after the engine is completely disconnected from the car, jack the car back up and make sure your engine doesnt tip over when you slide the engine out on the creeper.
This can be done with 1 person as i've always done it by myself and im only 5'7" 135 lbs
Old Jul 17, 2005 | 11:25 AM
Si Shane's Avatar
Default Re: motor swap without engine lift? (ADVAN EG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ADVAN EG2 &raquo;</TD></TR><TR><TD CLASS="quote">What i usually do is take off the front wheels and put a creeper under my motor. i then proceed to lower the car til the motor is resting on the creeper (DO NOT LET THE CAR REST ON THE CREEPER, JUST THE MOTOR). keep the jack holding the car in the same position then, unbolt all the mounts and anything else that is holding the motor there. after the engine is completely disconnected from the car, jack the car back up and make sure your engine doesnt tip over when you slide the engine out on the creeper.
This can be done with 1 person as i've always done it by myself and im only 5'7" 135 lbs </TD></TR></TABLE>
how do you jack the car up enouh to get the motor out? you must have one nice jack
Old Jul 17, 2005 | 11:29 AM
Stoich EG2's Avatar
Default Re: motor swap without engine lift? (Si Shane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Shane &raquo;</TD></TR><TR><TD CLASS="quote">
how do you jack the car up enouh to get the motor out? you must have one nice jack </TD></TR></TABLE>
oh yeah, i forgot, i have a professional shop jack, LOL
Old Jul 17, 2005 | 12:47 PM
Eg6xCiViCxSi's Avatar
ive done this before to my civic we lifted up the car as high as we could on jack stands then to lift the motor up we used a normal jack its possible ive done it 2 times
Old Jul 17, 2005 | 12:48 PM
hatchi's Avatar
i've done several swaps without lifts. all you need is some wood thick enough for the car to be lifted on and a floor jack or 2.
Choy
23
Mar 8, 2009 11:08 AM
PHILEE
May 9, 2008 11:50 AM
Acidcrakker
Oct 8, 2007 04:05 PM
LukieLuc
Apr 12, 2007 11:49 AM
turbohf
Feb 2, 2003 08:10 PM
