something very bad?!
Old Jul 17, 2005 | 07:49 AM
ceLtic*
Guest
Posts: n/a
Default something very bad?!
https://honda-tech.com/zerothread?id=1310807
ohhh man. what a long night....so im driving along and all of a sudden i hear "POW" and my car shuts off....and it starts back up. oK. fine.....i get to the light and the car just dies on me and wont start. [ls/vtec ctr pistons bc3+ cams rc 310injectors] and so on. now....after about 20 or so tries....its start up like normal....runs/revs all fine. then just hesitates and dies with loud back firing. I THINK the backfiring is cause im running RC 310 injectors and its dumping fuel into a hot motor and just spits it out, and POW.
my question is what could this be? bad spark plugs? bad injectors? bad distributor? what is going on..im so mad and in such a daze right now.... the engine will not throw any CEL's for the 1-2 minutes its running fine. anyone think the motor is blown? car has new water pump / oil pump /radiator as well. the car was not over heatting either...
Old Jul 17, 2005 | 09:10 AM
Combustion Contraption's Avatar
I can almost guaruntee its ignition related. Ill try and post more when i get off of work later.
Old Jul 17, 2005 | 09:35 AM
moto1320's Avatar
Default Re: (LsVtec92Hatch)
was the first "pow" a backfire or did it come from the engine bay? are you tuned, I assume you would have to be but figured I'd ask? what have you checked so far...If nothing then I would start with cam timing and ignition.
Old Jul 18, 2005 | 06:51 PM
ceLtic*
Guest
Posts: n/a
Default Re: (moto1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moto1320 &raquo;</TD></TR><TR><TD CLASS="quote">was the first "pow" a backfire or did it come from the engine bay? are you tuned, I assume you would have to be but figured I'd ask? what have you checked so far...If nothing then I would start with cam timing and ignition.</TD></TR></TABLE>
backfire. untuned.
Old Jul 18, 2005 | 07:25 PM
moto1320's Avatar
Default Re: (ceLtic*)
wow, hit the dyno before you destroy your motor. I'm surprised that it's running at what anyone would call "fine" at any point. That's a pretty voltile mixture you have there with that compression ration and engine management...or lack there of.
Acuronda_SloTeg
Jun 14, 2009 08:18 PM
castle1313
May 21, 2009 08:43 AM
nsone
Sep 4, 2008 06:22 PM
ceLtic*
12
Jul 19, 2005 08:11 PM
