Engine cuts off while driving.
Old Aug 14, 2008 | 07:59 PM
nsone's Avatar
Default Engine cuts off while driving.
My first assumption was the Fuel Pump is going bad.
The car starts fine. It only happens once in a while. Last night coming home from an hour distance, the car 94 LS died on me twice! outside temp was around 60-70s.
I pull off to the shoulder, completely turn off the car.. once, twice, on the third or fourth it starts again.
It's only died on me twice like that in town. And the car always turns on after a couple of "off-crank" tries.
After reading through the archived topics, now I have to consider the Fuel Relay going bad... but most of these cases have issues with starts as mine starts fine.
The car has the original motor with just about 250K on the clock.
Any suggestions?
Pump? or Relay?
thanks guys.
Old Aug 14, 2008 | 08:11 PM
Rediness_code's Avatar
Default Re: Engine cuts off while driving. (nsone)
Inspect distributor cap and rotor for wear.
Old Aug 14, 2008 | 08:20 PM
nsone's Avatar
Default Re: Engine cuts off while driving. (Rediness_code)
I considered spark components to be at fault, but the way the car dies .. I veered away from it.
While you're on the gas, it just literally cuts off. No stalling of any sort.. Bam, that's it.
Wait..... I do recall, during one or two of those Restarts after it died... It almost turned over, almost like it was flooded...
so... No fuel, or no spark?
dammit.
too many factors here!
Thanks for the reply.
Old Aug 14, 2008 | 11:05 PM
masonn187's Avatar
do you have an alarm?
could have to do with your ignition kill switch in the alarm
which is probly spliced into your ignition switch in the steering column
or your distributor
Old Aug 14, 2008 | 11:40 PM
Capo De Payne's Avatar
Default Re: Engine cuts off while driving. (masonn187)
ALternator not charching right? MAYBE. I could be wrong..
Old Aug 15, 2008 | 07:13 AM
nsone's Avatar
Yes there's an alarm but that's not the case here. Kill switch only works before start, not while the car is running.
Alternator isn't the culprit here, it's just not his style.
Anyone else? There' s got to be someone out there who has diagnosed this before...
*scratches head..
Old Aug 15, 2008 | 10:42 AM
nsone's Avatar
bump
Old Aug 15, 2008 | 11:12 AM
nsone's Avatar
bump for help so i dont have troubleshoot everything in this 100+ degree Cali heat!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
im meeelllttinnnggggg
Old Aug 18, 2008 | 12:58 PM
nsone's Avatar
quick followup.
Replaced Rotor cuz it was burnt out, checked Main relay, no wear on solder points.
Fuel pump primes everytime.
Narrowed down to= Igniter
will update if problem is solved one i find dizzy or part.
Old Sep 4, 2008 | 06:22 PM
nsone's Avatar
Default Re: (nsone)
Igniter module inside the dizzy replaced.
Just tuned up, seafoamed and lucas oiled..
runs better than ever and quieter with original motor at 250k!
ttcheung97
Aug 24, 2020 06:31 AM
WanaBeFaster
Nov 13, 2007 06:32 AM
civiccoupe94
Oct 28, 2007 08:32 AM
rtdillon
Nov 9, 2005 08:49 PM
trianglegreg
Oct 29, 2005 08:51 AM
