What do all the inlets and outlets of a fuel tank do?
Old Jul 17, 2005 | 01:22 AM
whole9's Avatar
Default What do all the inlets and outlets of a fuel tank do?
I cut all of these lines and really messed stuff up underneath, I was being retarded, I thoguht I was going to run a straight up fuel cell, but thats complicated and expensive. Can I buy all the fuel lines and everything new from Honda? I nkow I can buy the gas tank new, and the OEM fuel pump, but what else would I need to buy thanks all your help is greatly appreciated!
Old Jul 17, 2005 | 01:28 AM
whole9's Avatar
Default Re: What do all the inlets and outlets of a fuel tank do? (whole9)
Also which hole does the fuel pump get installed in?
Old Jul 17, 2005 | 03:19 AM
adeline's Avatar
smaller hole is the fuel sending unit and the big hole is for the fuel pump.
Old Jul 17, 2005 | 04:18 AM
whole9's Avatar
Default Re: What do all the inlets and outlets of a fuel tank do? (adeline)
ok and the three holes on the side?
Old Jul 17, 2005 | 04:19 AM
whole9's Avatar
and can you get all the connections and parts that connect to all these holes and everything completely new from a honda dealership? I know I can get the fuel pump and gas tank new, but can I also get the other parts new as well?
Old Jul 17, 2005 | 06:35 AM
wickedEFguy's Avatar
I found this, I hope it helps
Old Jul 17, 2005 | 06:53 AM
whole9's Avatar
Default Re: What do all the inlets and outlets of a fuel tank do? (wickedEFguy)
ya sorta except now I realize I really fucked up :[
Old Jul 17, 2005 | 07:30 AM
kid-honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whole9 &raquo;</TD></TR><TR><TD CLASS="quote">ya sorta except now I realize I really fucked up :[</TD></TR></TABLE>
It happens and now its a lesson to think ahead and a chance to learn something new, always look at the bright side
Old Jul 17, 2005 | 07:43 AM
whole9's Avatar
Default Re: What do all the inlets and outlets of a fuel tank do? (kid-honda)
ya cus I have no clue what any of that stuff in the picture is except the gas tank lol I wonder how much a shop would call to fix all that mby ill call monday
Old Jul 17, 2005 | 08:16 AM
NAS_OCSICNARF
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whole9 &raquo;</TD></TR><TR><TD CLASS="quote">ya cus I have no clue what any of that stuff in the picture is except the gas tank lol I wonder how much a shop would call to fix all that mby ill call monday</TD></TR></TABLE>
I wouldnt recommend a shop cause the working with the fuel tank can really become a bitch, thats were the big bux come out.
Old Jul 17, 2005 | 09:04 AM
whole9's Avatar
Default Re: What do all the inlets and outlets of a fuel tank do? (NAS_OCSICNARF)
ya there is really no turning back once you drop it, cut the lines, and give all the parts you had to the local junk yard *doh!*
Old Jul 17, 2005 | 09:42 AM
KingKhong's Avatar
i just replaced the tank on my crx, so but i dont remember which one goes where. but i remember the bigger pipe on the bottom right goes to the nozzle or whatever you call where you fill it up at. the one above that also goes to the thing you use to fill it up you'll see what i'm talking about when you look at it. there should be a fitting that goes to your pump that screws in so i hope you didnt cut that up and i'm not sure where the other ones go, but there are 3 metal tubes that come out by the tank you just gotta figure out which one is which. sorry i dont remember exactly where each goes. good luck
Old Jul 17, 2005 | 11:15 AM
RCautoworks's Avatar
Should help a little more
Old Jul 17, 2005 | 11:33 AM
99teggsr's Avatar
get the fuel cell, you already F++KED UP your car prepping it for that.
jastonian106
Feb 28, 2015 09:03 PM
hondaapi
May 13, 2010 11:39 PM
Jonathan_ED3
May 20, 2008 03:04 PM
BLKCRX
Sep 12, 2003 08:14 AM
