Power window adjustment -- searched
96 HX w/ power windows...
It doesn't seal all the way. I tried moving the track back and fourth (on the front) but that makes it leak air either in the front or in the back, no matter how I adjust it.
The previous owner had window problems, apparently replaced the motor, but didn't get it back into place correctly. It rolls down a little too far, and doesn't roll up far enough. I'm thinking I need to make the whole thing move up a little, but with the door panel off and me poking around, I can't see how to do that at all...
Any ideas?
Any ideas?
You need to have the panel off so that you can watch things happening and usually the problem will present itself and/or give you the ability answer questions for people willing to help you...outside of that you will have equal luck with a magic 8-ball or psychic friend.
I got the same problem man. First my windows wouldn't go up, fixed that... now they won't seal on the drivers side. Like you I tried to adjust it, I think maybe a new track would fix it, but I am not totally sure. If anyone knows a solution for all of us post it up, I can't stand the air noise.
hondapwr
Jul 28, 2007 06:55 PM
