alternator & bracket question
Old Jul 16, 2005 | 09:42 PM
tonezilla's Avatar
Default alternator & bracket question
i am using an accord alternator with a h23 bracket on a h23a1 . and my ac/alternator belt is slipping bad . i dont have any of the adjustment bolts or pieces with the bracket, so it is just tightened down by the alternator mounting bolt and nut . but before i buy the bolts and pieces from honda, i wanted to know if anyone knew if the accord and prelude alternator is the same ?
Old Jul 17, 2005 | 11:53 AM
BB4vTak's Avatar
Default Re: alternator & bracket question (tonezilla)
im using a accord alternator on my jdm h22, no problems, also used it on my old h23 with no problem... If your missing tentionsing stuff have a freidn ciome over and pry against it to tighten it up while you lock it down hope that helped
Old Jul 17, 2005 | 10:39 PM
tonezilla's Avatar
Default Re: alternator & bracket question (BB4vTak)
yeah i tried that with a friend but it is still slipping . so i need to buy the adjusment bolt and pieces to see if it would tighten it better . but i dont know if it will work with the accord alternator . it doesnt only slip when i start the car, but it also slips when i step down on the clutch and also when i am turning . so does anyone know ? i never had this problem before with other belts, but could it also be because its a new belt ?
Old Jul 18, 2005 | 04:30 AM
AndyD's Avatar
If you need an H23 alternator with the H23 pulley, let me know. I have on. I might even have the tensioner bracket too. I can check if you need it.
Old Jul 18, 2005 | 07:03 AM
v4lu3s's Avatar
RTFM
they are the exct smae alternator, but they each have a slightly different sized pulley.
nweldon92
10
Jan 28, 2018 01:00 PM
bseballkid1990
Apr 27, 2012 08:47 PM
moLAL24
Apr 11, 2009 06:27 AM
shooitzlinh
Jan 8, 2004 04:03 PM
