DESPERATE help with electrical issue (CKP code 4)...possible short ? [PICTURES]
Old Jul 16, 2005 | 06:06 PM
daklown's Avatar
Dat Dere Cell Tech
Default DESPERATE help with electrical issue (CKP code 4)...possible short ? [PICTURES]
One day...all of a sudden...my car was setting a rev limiter at 3500 RPM. I checked the code...CKP code 4...crankshaft position sensor.
Here is what I have tried so far:
2 distributors
Another ECU
Adjusting Distributor
New plugs and basic crap
I've decided its probably an electrical issue...and I'm pretty new to electrical stuff. I picked up a factory manual from someone and made some copies and im following step by step. Everything seemed to be OK up until the point where I check for continuity from body ground to the pins on the ECU harness that run to the sensor...
these are my results...
This is my ground connection (I guess its ok...i put it on there tight but then again i dont know what im doing. The carpet is pressing against it pretty well.
This is my reading when i test one of the pins in question:
And this is the other....(as it SHOULD be i believe)
Car has sat for 2 months while I bum rides to work...so id really appreciate some help so I can get to school in august.
Old Jul 16, 2005 | 07:03 PM
Sly_Samba's Avatar
HTBATRACER
Did you try a new CPS?
Old Jul 16, 2005 | 07:11 PM
daklown's Avatar
Dat Dere Cell Tech
I replaced the distributor a couple times...I was under the impression that it was inside the distributor itself.
Old Jul 16, 2005 | 09:01 PM
hatchgrl's Avatar
Its actually next to the crank on the timing belt side, behind the cover.
Old Jul 16, 2005 | 09:12 PM
becoming's Avatar
Default Re: DESPERATE help with electrical issue (CKP code 4)...possible short ? [PICTURES] (daklown)
I have an extra cps if u need it, just as long as you car is obd2. let me know, e-mail me at showell29@msn.com if u do. good luck
Old Jul 16, 2005 | 10:46 PM
daklown's Avatar
Dat Dere Cell Tech
hmm
i assume the CKP has to have something to reference...so ill look for that sensor. Dont remember messing with one when i did my harnesses before...but hell i forget a lot of things.
Im really interested in figuring out what that meter is saying first though.
Old Jul 17, 2005 | 05:50 AM
daklown's Avatar
Dat Dere Cell Tech
Bump before work
Old Jul 17, 2005 | 06:02 AM
2lua's Avatar
Default Re: (daklown)
this assume that your car is obd1? more info on the car model and year.
for test and check on electrical you should use the t-pin (they sell then at the craft and yarn store) and use aligator clip for better grip and connection.
Old Jul 18, 2005 | 11:42 AM
daklown's Avatar
Dat Dere Cell Tech
Bump before work
Old Jul 18, 2005 | 11:43 AM
daklown's Avatar
Dat Dere Cell Tech
...fixed.
It was a short after all.
Old Oct 4, 2008 | 04:54 PM
kaddi88's Avatar
Im havin a similar problem, changed ecu's dizzy and such, but do u remember were the short was? i just dont know were i would start looking, cuz im waiting for a meter. thanx
Old May 6, 2010 | 07:35 PM
xkrazyxjbrkerx75's Avatar
do u remember where the short was? im having the same CEL CODE 4, ckp, car idles at 1500 rpms. and rev limiter is 3500...
Old May 6, 2010 | 07:36 PM
raidacaipo's Avatar
this thread is 5 years old man.. lol well at least your doing some searching before making another post so kudos to you. But I dont think the OP is going to respond
nonvteclude
Dec 29, 2006 09:22 AM
oldschoolfreak
Mar 25, 2005 06:18 PM
Prelude MIke
Apr 22, 2004 07:34 PM
se93
Sep 23, 2003 07:25 AM
wreckedagain
May 12, 2002 06:43 PM
