ohh my gosh!
Old Jul 16, 2005 | 05:27 PM
Madrek's Avatar
Default ohh my gosh!
Today while driving in the rain I noticed my car was acting funny...no power...I pulled over and it almost died...I check my cold air intake (took it off) and wtf water comes out...I left it off and drove it home...It seemed fine but I didnt want to gun it since I had no filter for about 1000 yards...could my motor be good still or is this the end? I hear about motors hydro locking is that when it wont turn over (please explain)...I also read that people change their spark plugs and their motors are fine...any help at all would be great!!!!! thanks in advance
Old Jul 16, 2005 | 05:29 PM
slow99si's Avatar
Default Re: ohh my gosh! (Madrek)
my buddies ar took in some water but it immediately seized and smoked the entire road ...
Old Jul 16, 2005 | 05:30 PM
Madrek's Avatar
should mine be ok since i drove it home?
xEnderx's Avatar
Default Re: ohh my gosh! (slow99si)
When you hydrolock you'll know it. Sounds like you just got lucky. Remember.....water doesn't compress.....thats why it bends rods.
Old Jul 16, 2005 | 05:32 PM
neutron91's Avatar
Default Re: ohh my gosh! (xEnderx)
if i were you i would take the plugs out and unplug the dizzy and crank the motor over a few times... this will get any water out of the cylinders... then do an oil change... if you made it home and it was still running you should be ok
Old Jul 16, 2005 | 05:33 PM
Madrek's Avatar
thanks for the replies
Old Jul 16, 2005 | 06:40 PM
scott92hatch's Avatar
it all depends how much water u took in an if it seemed fine after u took the intake off u might just get lucky
Old Jul 16, 2005 | 08:57 PM
Han Solo's Avatar
When you hydro-lock itll happen instantly and youll notice. i think u stopped just in time, cause if it was acting funny u mightve had water in the filter and werent getting any air to the motor.
Old Jul 16, 2005 | 10:07 PM
crashN2u's Avatar
Default Re: ohh my gosh! (jdmdelsolb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neutron91 &raquo;</TD></TR><TR><TD CLASS="quote">if i were you i would take the plugs out and unplug the dizzy and crank the motor over a few times... this will get any water out of the cylinders... then do an oil change... if you made it home and it was still running you should be ok</TD></TR></TABLE>
:thumbuup:
Old Jul 16, 2005 | 10:08 PM
Hatch It's Avatar
Default Re: ohh my gosh! (neutron91)
Best thing you can do, good luck
Old Jul 16, 2005 | 10:18 PM
romoracing's Avatar
Default Re: ohh my gosh! (Hatch It)
another thing to do is by a bypass valve!
Old Jul 17, 2005 | 02:14 AM
Toxidomask's Avatar
I did this in my pick up it works, esp. after washing my motor. But the problem with honda's are the plugs are directly on top, and the sleeves where the plugs insert too; wont water be just going back down to the cylinder? I wonder if you could take all your plugs off, then turn cyl 1 to TDC then use some kind of wet vac figure out how to insert it inside the plug sleeves to get the water, then go turn to cyl 3, then 4 then 2, and so on. what you guys think? too much work? or will it work?
Old Jul 17, 2005 | 05:01 AM
92ehatch's Avatar
Default Re: ohh my gosh! (Toxidomask)
thats a close call man. get this
i bought my 93 lx it had a second motor, well whoever put it together, got OIL in the stock intake hose, i drove it a whole month!!!! before putting my intake on it, so i didnt even know. good thing it was oil and was thicker, i checked the TB and no oil in there that i could see. whoooo close call
Old Jul 17, 2005 | 10:41 AM
neutron91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toxidomask &raquo;</TD></TR><TR><TD CLASS="quote">I did this in my pick up it works, esp. after washing my motor. But the problem with honda's are the plugs are directly on top, and the sleeves where the plugs insert too; wont water be just going back down to the cylinder? I wonder if you could take all your plugs off, then turn cyl 1 to TDC then use some kind of wet vac figure out how to insert it inside the plug sleeves to get the water, then go turn to cyl 3, then 4 then 2, and so on. what you guys think? too much work? or will it work?</TD></TR></TABLE>
trust me if your car makes anything for compression that water is coming out whether it be a honda or v8
Old Jul 17, 2005 | 10:46 AM
EKCRX-Ihadastupidusername's Avatar
Exactly why I wont buy a CAI. When my **** blows, if I got money &gt; H22, if not I'll drive it off a bridge before going back with D series.
Old Jul 17, 2005 | 12:26 PM
neutron91's Avatar
Default Re: ohh my gosh! (diegoaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diegoaccord &raquo;</TD></TR><TR><TD CLASS="quote">Exactly why I wont buy a CAI. When my **** blows, if I got money &gt; H22, if not I'll drive it off a bridge before going back with D series.</TD></TR></TABLE>
well instead of driving it off a bridge just hit me up... ill take it off your hands
Old Jul 17, 2005 | 01:13 PM
96CivicBoostCoupe's Avatar
dont forget to change your oil, water makes foam in an oil pan
Old Jul 17, 2005 | 01:29 PM
Kool305's Avatar
Default lucky
close call,
i wasnt that lucky (about a year ago)...
good for u man...i sure learned my lesson...
since then... i've been running a short ram intake
Old Jul 19, 2005 | 09:59 AM
Madrek's Avatar
Thanks for the replies again...Took out the plug and turned it over...then did a oil change...She seems to be doing just fine...I was for cure not going back to a d series..damn I guess I got lucky!!
Old Jul 19, 2005 | 10:41 AM
young noob's Avatar
Default Re: (Madrek)
are you still at a threat on a turbo charged car with a front mount?
Old Jul 19, 2005 | 10:53 AM
B-twentyVTEC's Avatar
dang
Old Jul 20, 2005 | 04:07 PM
Default Re: (Mr_WETTY)
glasd to hear you made out allright
Old Jul 20, 2005 | 05:38 PM
its ok to drive home
oneprelude
Nov 30, 2008 05:45 PM
94eh2
21
Mar 31, 2007 08:13 AM
Red4drLSintegra
Dec 12, 2006 06:11 PM
mcgee*
33
Jun 10, 2005 09:37 PM
geminis2k
Jan 31, 2004 05:52 PM
