crx converted to obd1 check engine light ?????????????
Old Jul 16, 2005 | 12:14 PM
crxvtecturbo's Avatar
* B A N N E D *
Default crx converted to obd1 check engine light ?????????????
i have a crx with hondata s200b with obd1 conversion and my check engine light came on when i was driving so when i ground out the service connector i get a soild light then when i unhook the service connector and turn the car over to on positon to check engine light goes away but when i start it it comes on and stays on
can someone tell me what to check to get rid of this light
Old Jul 16, 2005 | 12:17 PM
NikoZai's Avatar
Default Re: crx converted to obd1 check engine light ????????????? (crxvtecturbo)
should have a stored code from starting it.
Sounds like you're going through the steps correctly. If it has a code stored from the last engine firing, you'll still turn it to the off position, connect service connector, turn it to just the on position, and it should flash the code that caused the check engine light... if nothing.. then thats very odd.
Not too familiar with the hondata shtuff, but i believe that part stays the same.
Old Jul 16, 2005 | 12:26 PM
decklyn18's Avatar
Default Re: crx converted to obd1 check engine light ????????????? (NikoZai)
sorry to ask but this connector u guys talk about (service connector) what or where is that
Old Jul 16, 2005 | 01:30 PM
2point2's Avatar
could be an ECU issue..
Old Jul 18, 2005 | 09:45 AM
ALLMOTORCRX20's Avatar
Default Re: (2point2)
To get to the service connector you have to take off the glove box. It's probably taped up with the rest of the other harnesses. I believe the plug is white with 2 wires. It should be the only plug with 2 wires. There will probably be another plug with 3 wires, but that plug is not important. You need to put a paperclip from one wire to the other. Your check engine light will blink a code. Long blinks are 10 and short blinks are 1.
Old Jul 18, 2005 | 09:33 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: (ALLMOTORCRX20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALLMOTORCRX20 &raquo;</TD></TR><TR><TD CLASS="quote">To get to the service connector you have to take off the glove box. </TD></TR></TABLE>
no u dont. it's under the part between the box and door by the carpet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALLMOTORCRX20 &raquo;</TD></TR><TR><TD CLASS="quote">I believe the plug is white with 2 wires. It should be the only plug with 2 wires. </TD></TR></TABLE>
it's eather blue or gray. 2 wire is CEL check conector. 3 wire is DLC (data link conector or "Datastream")
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALLMOTORCRX20 &raquo;</TD></TR><TR><TD CLASS="quote">You need to put a paperclip from one wire to the other. </TD></TR></TABLE>
any metal object will do
Old Jul 18, 2005 | 09:41 PM
DohcVtecCrx's Avatar
Default Re: (DieMaster)
Hmm before everyone gets carried away with under the dash connector, maybe they should find out what year it is....88-89 are in the engine bay, 90-91 are in the car under the dash. You use the timing jumper for it.
Old Jul 18, 2005 | 09:49 PM
DieMaster's Avatar
Default Re: (DohcVtecCrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DohcVtecCrx &raquo;</TD></TR><TR><TD CLASS="quote">Hmm before everyone gets carried away with under the dash connector, maybe they should find out what year it is....88-89 are in the engine bay, 90-91 are in the car under the dash. You use the timing jumper for it.</TD></TR></TABLE>
your right forgot to say that. sleepy that is on EG stock obd1 harneses. EF'sdont have that stock.
G. Man
12
Feb 25, 2011 06:13 PM
SmogKing
Aug 3, 2006 12:48 PM
crxvtecturbo
Jul 14, 2005 07:48 PM
hotimportcrx
Jan 15, 2005 11:38 PM
VTECVillain
Jan 6, 2002 11:40 AM
