Wheel Wobbles
this isnt google. next time wait more than 6 mins before bumping. something obviously loose. look for loose bolts, that should fix your proble. probably the caliper bolts. are the 2 screws in the rotor?
How do you know that the wheel is wobbling? Are you sure that the rim isn't bent? It's okay for the rotor to move around on the hub. The caliper keeps the rotor in place if you don't have the two retaining screws in it.
i had that same exact problem... im sure its the wheel bearing get it replaced immediately! because when your driving im sure u dont want your car to fall apart when that bearing goes out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nutar »</TD></TR><TR><TD CLASS="quote">replace the bearing or grab a differant lower arm with a good bearing</TD></TR></TABLE>
slywfbpsi
15
Sep 4, 2009 02:58 AM
CXHatchback
Oct 16, 2003 04:16 PM
